3vze auto to 5 speed swap.. need info on what i need
Subscribe
Sep 9, 2008 | 07:50 PM
i have a 95 4runner with an auto trans and would like to make it a 5 speed... i was just wondering what parts i would need for that
Thanks
Reply 0
Sep 9, 2008 | 07:58 PM
Have you tried to " search " for results?
There are many articles about it.
Heres one; https://www.yotatech.com/forums/f116...d-swap-117391/
If you google your desired mod, I am sure you could get more links from other forums.
Good Luck
Reply 0
Sep 9, 2008 | 08:42 PM
you will need:
-transmission
-shifter kit
-rear drive shaft
-ecu (or you can hot wire and make it work)
-bell housing
-cross member
-complete clutch assembly (clutch, fork, slave and master cylinders, hard lines, etc)
-pilot bearing, flywheel
-pedal assembly
-shift boot and interior trim
If I think of more, I'll add it.
Reply 0
