I am looking for a Toyota Pick Up Truck where the engine doesn't have any electronic components.
With an automatic, 4X4, greater than 175 HP (preferably a V6), and greater than 18 miles per gallon if possible.....
Any suggestions?
Any suggestions?
Any suggestions?
The earliest V6 toyota 4x4 only had about 150 hp (3.0L) and is EFI (1988-1995).Originally Posted by andrewmitch
I am looking for a Toyota Pick Up Truck where the engine doesn't have any electronic components. With an automatic, 4X4, greater than 175 HP (preferably a V6), and greater than 18 miles per gallon if possible.....
Any suggestions?
OK....how about something older then? Like the 4 Cylinder Turbo 4X4? Do I hear 150 HP and 16 MPG??? But still with no electronic components...
Yeah, if you can find one. But still that is less hp and mpg than you asked for.
The things you want aren't helping each other. Any toyota that has enough power and mpg for you is going to have plenty of electronic things.
Personally I would go with a tacoma or 4runner with a 3.4 in it already, but then you have electronic components. Otherwise you could go with an older truck with a 22r and get the mpg and less or no electronics and less or no power. Try to solve that and your spending a ton of $$$ and will lose the mpg. You can always swap a domestic v8 or v6 in too, but then your mpg suffer.
See where this is going?
OK....then how about a 4X4 with good gas mileage and no electronic components (forget the engine size and power).........but in an automatic.......
Sponsor
what do you have against EFI?! if you really want to deal with vacuum lines and a carb look for a truck with a 22r 79-84 is going to be your best best, but there were available up to 87.
OR, Find your self a truck with a 22re and i'll give you my 22r in exchange for your 22re and ecu.
and learn to drive stick
let me see what i can find in those years w/ the 22r
did they make a turbo charged w/OUT EFI?
as far as the turbo w/o efi i highly doubt that, and ive never seen an automatic that didnt have efi, theres a handful of efi automatics with the 22re
Sponsor
if you want to import from the UK............. then yes you can get a turbo diesel. hell you can even get it in a V6 if i remember correctly. but good luck finding it in the states.
I know in the 84-85 models they had a deisel. I'm not sure if it a turbo. but the parts are really hard to find. and so are the trucks.
You can drop a VW diesel engine (1.6 or 1.9 n/a or turbo, IDI engine, not the TDI) into a Toyota and have pretty basic engine. Only needs 12 volts for the fuel cutoff solenoid and the radiator fan and wiring for any senders for gauges or idiot lights as needed. A tuned up 1.9 turbo can do pretty good power and torque wise.
Although not sure if anyone makes an adapter for the automatics, they have them for the 5 speed gear box. Note that the Toyota automatics are electronic (ECT):
- http://autoshop101.com/forms/h16.pdf
You could get an older FJ40/55/60 and get a non-electronic engine, but gas mileage is not in your range. Although having owned an FJ55 with in-line-6 (F) engine and now a 4Runner w/ 22RE, I would take the 22RE any day. It is a really simple EFI setup, easy to work on and very reliable. And that engine/vehicle gets nearly twice the MPG of the old FJ55
get an old mid 70s yota pick up put the body on an early 80s yota frame, slap a v6 or small v8 in it and your good to go.
the 70s body is so you dont have to pass smog.
the 80s frame is so you have a nice srontg frame with the sraight axle under it.
and you get to chose the engine.
if you want to keep it yota then go with the 3.4l engine gets good mpg and has good power, but it has electronics.
or go with a chevy small block has tons of power and if you get the right year you wont have electronics but be prepared not to pass many gas stations.
thats all the help i can be to you.
Another thing- around here at least its practically impossible to find an automatic 2wd, much less a 4x4 automatic, which IIRC, wasn't even possible until 1985?
Anyway, bottom line is, what do you want more? For example, you could get a hold of a 79-83, do some performance mods, and maybe get close to 150hp. Then you'd have little electronics, 4x4, but it would almost have to be a stick unless you swapped an automatic from a later year. Thats my suggestion.
is there some resource guide where I could look up the specs of all out of production pick up trucks??
you wanta 70s fj 40..dont we all
my 1987 22r pickup has no electronics!!!
im gonna go propane! and get rid of that carb
