Just out of curiosity, what kind of welder are you using?
Project looks good! I'm planning on doing some fab work on my newly acquired '91 pickup but that will have to wait till after the house stuff is fixed. :) |
Originally Posted by slo6i
(Post 52077530)
Project looks good! I'm planning on doing some fab work on my newly acquired '91 pickup but that will have to wait till after the house stuff is fixed. :) Tomorrow I will be getting some 14 gage sheet metal to "skin" the body frame work that I built. I will be getting one 4x8' sheet to do the bedsides, and I'll have to order the 5x10' sheet. That should be enough material to do the floor, tailgate and the front header panel. So hopefully I'll have some updates with pics in the near future! |
4 Attachment(s)
Finally got some work done on the trailer project. I finished building all my links, and got the main part of the trailer tongue built. I also got the air helper spring brackets all welded up and gusseted, I ran out of wire again, so I need to finish up some welds, then I can mount the firestone air helper springs and run the air lines.
I also bought the 4x8' and 5x10' sheets of 14 gage sheet metal for the floor and bedsides, just need to cut them into the correct sizes. I can't believe how fast the 1" square tube frame I built a few months back has rusted! I had it in the carport, but must have gotten enough moisture to rust, so now I have a lot of prep work to do before priming!... Here's a few pics... Attachment 156507 Attachment 156508 Attachment 156509 Attachment 156510 |
looking great bud!!! keep up the great work!!
Looks sick!
Originally Posted by bone collector
(Post 52100611)
Originally Posted by '85 Yota
(Post 52100645)
Looks sick!
1.) Build mounts on the 1" frame work and also on the trailer frame (I don't wont to drill into the trailer frame if I don't have to so I'll probably build some tabs to mount the bed/box to. 2.) cut out the 14 gage sheetmetal into the size panels I need and tack them in place. 3.) build the tail gate frame work out of 1" square tube, I have just enough left over to do this 4.) get some more welding wire and attach the trailer tongue, add gussets and reinforce the area where it attaches to the main trailer frame. 5.) finish up all the final welding on the trailer frame, then prime and paint... I would like to use POR15, but not sure if it's in the budget at this time. 6.) mount the Firestone air bags 7.) decide on whether to build trailer fenders or just buy some 8.) build a lockable hard top cover for it 9.) paint the body red to match my 4runner (fenders and hard top black) I'm sure I'm forgetting stuff like wiring and lighting, but that will be a ways away. I was originally planning on having shocks on it, but since I switch from running coil springs to air helper springs, I don't think I will need shocks, what do you guys think? |
Maybe im blind but whats gonna keep the axle from flopping forward or back? I doubt the track bar would do the job offroad?
Originally Posted by Inu
(Post 52100716)
Well time will tell. I would ad a link just inside the driverside bag to the link frame. If you left the frame side even with the lowers. It will act like ladderbars but no binding.
(Post 52100793)
4 Attachment(s)
Attachment 155457
Attachment 155458 ^^^Today I got the trailer tongue welded into place, I added this brace for strength, I have some 1/4" thick plate steel, I'm thinking about cutting out a triangle shape and fill in the center area Attachment 155459 Attachment 155460 ^^^my new toy, it's only a 8" drill press, 5speeds, 2.5 amp motor, got it brand new in the box for $30, will see how it holds up! |
looking good.
Originally Posted by INFINITY
(Post 52106529)
looking good.
I've been getting some more done on the trailer, a little each day before work, been cutting up the 14 ga sheet metal and welding up the sides of the box, I'll try to get some pics posted up in the next day or so. |
5 Attachment(s)
I got some work done on the trailer today, I got both sides and the front of the box sheet metal in place. The drivers side is fully welded all the way around. The passenger side and front are stitch welded in place, but need to finish up welding up the seams all the way around.
Attachment 154793 ^^^Here is my make-shift bending brake, I clamp a piece of 1" square tubing to the sheet metal and used a grinder to cut a scribe line to make it easier to bend, then just took my big cresent wrench and used it to bend it over, worked good! Attachment 154794 ^^^ Here is the end that I bent, so it would wrap around, that way the tailgate sheetmetal will flush up to it, if that makes sense, lol Attachment 154795 Attachment 154796 Attachment 154797 I have all the parts cut out to build the tailgate, I'll try to get them welded up tomorrow,I still need build mounts so I can bolt the box down to the frame, then I can cut out the sheet metal for the floor and weld that in. With the changes that I made to the width of the trailer I'm pretty sure that I'll have to run wheel spacers, I'm going to, eventually get some black steel rims with the same offset as my 4runner, then I'll figure out how wide of a wheel spacer I need. |
This is coming along very nicely. Glad to see ya getting back to work on it.
3 Attachment(s)
Originally Posted by Redeth005
(Post 52109967)
Today I got the tailgate pretty much built, need to finish up some welding on it and get some hinges, I got a plan for the latching mechanism, I'll go into more detail on that later, also I have the tailgate holder upper thingy (that keeps the tailgate from falling all the way down, don't know what you call it, lol) off of my old 83' pickup that I'm going to use on this... Attachment 154731 Attachment 154732 Attachment 154733 |
Nice. I belive the word you're looking for is a "latch"? like what i used on my tire carrier? one on each side maybe?
1 Attachment(s)
(Post 52110307)
Attachment 154730 *EDIT* ^^^This is what I was talking about, lol |
Limit straps. Id just use cable
Looking good |
1 Attachment(s)
(Post 52110321)
Looking good I made some hinges for the tailgate, just need to do some grinding and minor trimming to make the tailgate open properly. The outer 14ga sheet metal skin that I welded to the tailgate is rubbing not allowing the tailgate to open, so I'll fix that. I originally planned on building a rear bumper and mounting the tail lights in the bumper, but now I'm thinking of mounting the taillights in the tailgate, and also the sinking the license plate into the tailgate as well, something like this: Attachment 154475 |
