Offroad/camping/utility-all in one trailer build
7 Attachment(s)
I started this project over a year ago. The goal was to build an offroad capable camping trailer that I could pull double duty with. Since I had sold my DD truck to help finance the build on my 86' 4runner, I wanted to build a trailer small enough to run trails, yet big enough to haul some lumber (or a sheet of plywood) home from the local hardware store.
The plan, make the inside dimensions 50"W x 72"L with the tailgate down around 96"L) Also instead of using leaf springs I wanted to do a 3-link suspension with Jeep TJ coil springs. I'm using a 3500lb rated trailer axel, It's actually wider than the Toyota axel width (it's 63" from hub to hub) but I had to run a wider axel to get the 50" inside trailer width I was shooting for. I bought some brackets from Ballistic Fab to mount the coil springs to the trailer axel and to the frame. I also bought shock tabs, and tabs to mount the links, and some poly bushings for the link ends. I pretty much got the majority of the trailer frame built last year (minus the tongue/hitch) using 2x3" tubing. Attachment 166165 Attachment 166166 Attachment 166167 Attachment 166168 Attachment 166169 Attachment 166170 Attachment 166171 ^^^These are the 33x12.50" tires (gotta love the centerline directional rims!) I'm going to run for now, just scored them today I traded the 31"x10.50's that were on my 83' Toyota for these. Now I will have 2 for the trailer and a spare for the trailer and a spare for the 4runner. I have another set of 31"x10.50's that I'm going to put on my 83'. |
1 Attachment(s)
I know I'm probably forgetting a lot of info since I started this project last year, so I will try to update and edit adding info as I remember it.
I have followed DIRTCO's camping trailer build and will be happy if mine turns out half as nice! I am open to suggestions and have never attempted a 3 link setup before, but figure since I don't have to worry about axel wrap on a trailer it should be pretty forgiving, lol. Here's a pic of my 4runner that will be towing the trailer, with the 302 V8 I should have plenty of towing power over the stock 22re. Attachment 166164 |
3 Attachment(s)
Today I went and bought some steel, I got 8-1/2 feet of 1-1/2" square tubing .250 wall, to use for my 3 link. And I bought some 1" square tubing to use as the frame work for the bedsides. The shop only had one 20' stick, so I had to order the rest and will have to go back and pick up the other 3 sticks in a couple days.
The main reason I decided to use the square tube for my links instead of round tube was because I don't have a tubing notcher, I have notched round tube by hand with a grinder, but it was a pain, I just figured it would be easier to notch the square tube and keep both sides even. I didn't get very much work done on the trailer today, I got one side of my panhard bar notched. Attachment 166053 Attachment 166054 Here's a pic of the shock tabs I have and also the axel tabs that I'll bolt my links to Attachment 166055 http://www.sierra4x4trailers.com/wp-...-trailer-1.jpg ^^^This is the basic look I'm trying to achieve when I'm finished, hopefully I can come close, lol. |
subscribed! I was thinking of doing something very similiar
3 Attachment(s)
Today I got the frame built out of 1" square tubing for one of the bedsides. It measures 73"Lx 24"H. The 1" tubing that I ordered was supposed to come in yesterday, but won't be in until Friday so I cant start on the other side yet.
I still need to order some Jeep TJ coils off Ebay, I will probably use the rear coils, they are a little shorter than the front ones. Attachment 165869 ^^^It looks kinda out of square in the pics, but it's just an illusion, lol Attachment 165870 Attachment 165871 ^^^I thought I'd roll a tire in and get a visual of how it might look, it will definitely sit higher than this once the coil springs are installed. |
Sweet! Can't wait to see it, sub'd.
Edit: I forgot to say nice 4Runner, that thing is pretty. I'd love to see under the hood, although I don't wanna derail this thread. |
1 Attachment(s)
Originally Posted by yotasavg
(Post 52056782)
Edit: I forgot to say nice 4Runner, that thing is pretty. I'd love to see under the hood, although I don't wanna derail this thread. *EDIT* HERE IS A PIC OF WHEN I FIRST DID THE ENGINE SWAP Attachment 165767 |
Looks good Ed what kind of hitch are you going to use.
lookin good! that thing would be really nice for long trips, if only i wasn't afraid to drive my truck on long trips....
Originally Posted by liveoffroad
(Post 52057137)
Originally Posted by Chuckar
(Post 52057080)
http://ts3.mm.bing.net/th?id=H.47831...h=134&c=7&rs=1 |
Would there be any issue with running the offroad style all the time? I don't know anything about trailer laws...
(Post 52057201)
(Post 52057137)
I don't think most of the offroad hitches are DOT stamped/legal, that's one possible issue.
The only other I could think of, would be the trailer wanting to wander a bit more due to wind or uneven pavement. |
This trailer is going to be sweet. Best of luck!
Originally Posted by rustEDyota83
(Post 52057197)
Thanks Tom, I think I'm going to make the trailer hitch with a receiver end so I can switch back and forth between a standard ball/hitch for highway towing and change it out to an offroad style hitch for offroad use. I'm going to try to build my own version of the "Max Coupler" hitch. I just can't afford to spend $250 for one, lol.
Originally Posted by niall
(Post 52057232)
Originally Posted by Chickenman
(Post 52057313)
(Post 52057326)
Ed check out this one http://www.tnttt.com/viewtopic.php?f...4959&start=165 scroll down 2 posts don't know if it will help but somthing to look at.
Thanks for posting the engine shot, looks good and I like how clean it looks under the hood. Lots of space would be a nice change...
(Post 52058211)
