so a little bit more cutting :)
http://i76.photobucket.com/albums/j2...y/SSPX1299.jpg also .. interior is now completely gutted .. http://i76.photobucket.com/albums/j2...y/SSPX1303.jpg anyone need some good floor boards ? :) . |
my first bend with my new bender :)
2" OD Sced 40 http://i76.photobucket.com/albums/j2...y/SSPX1306.jpg It's actually going to be my bend tool .. so I'm going to try out my powder coating as well with powdercoating it and saving it http://i76.photobucket.com/albums/j2...y/SSPX1305.jpg I have to still "draw" up my tube work in my solidworks software so stay tuned .. STOKED !! . |
added some rear suspension today ..
not done yet , still some tube to add , but the rear is off the jack stands :) http://i76.photobucket.com/albums/j2...029_picnik.jpg http://i76.photobucket.com/albums/j2...030_picnik.jpg http://i76.photobucket.com/albums/j2...032_picnik.jpg http://i76.photobucket.com/albums/j2...033_picnik.jpg . |
As always looking. Wish I was closer to come over and learn a thing or two.
mght even put you to work :)
Slacker I bow to you're awsomeness!! I have been kicking the idea around of doing something like this to a 91 that I can pick up pretty cheap. Love the custom frame, and I will be stalking this thread like a psyco ex girlfriend on meth!!!!
thanks ..
found some time today , so I finally cut the floor out for the body drop http://i76.photobucket.com/albums/j2...d/SSPX1310.jpg http://i76.photobucket.com/albums/j2...d/SSPX1309.jpg . |
prepping the inner rockers for the new body mounts .. I of course found rust :( .. so now I have to fix that first .. I was really surprised , this cab was in awesome shape no rust at all , or so I thought .. just goes to show you , even if you think you have no rust .. you probabally do !!
undercoating wire wheeled off , and looking great http://i76.photobucket.com/albums/j2...d/SSPX1312.jpg and cut out rust !! http://i76.photobucket.com/albums/j2...d/SSPX1311.jpg . |
also got the drivers side cleand and prepped this weekend
http://i76.photobucket.com/albums/j2...d/SSPX1315.jpg and :( .. drivers side has rust as well http://i76.photobucket.com/albums/j2...d/SSPX1316.jpg I think to be safe , i'm going to cut it all out .. front and back rocker area , and strengthin both sides before I build the body mounts and just for some giggles .. heres the pile of removed edging and ground steel .. http://i76.photobucket.com/albums/j2...d/SSPX1314.jpg . |
Yep cut that crap out. You know the deal. If you skip it, it will haunt you later.
absolutly ..
wow i'm not even sure that i know what's happening here anymore.... What's going on with the rear drive setup? looks awesome!
went back and reread the beginning, now it all makes sense, idk how i missed that... this is even better than i thought it was going to be lol! NOW I'M REALLY IMPRESSED!
thanks .. stay tuned ..
this build is going to be NUTZ . |
so over the last week , I have been building my repair panels and today I was able to get them burnt in , rears as well
http://i76.photobucket.com/albums/j2...SSPX1315-1.jpg http://i76.photobucket.com/albums/j2...d/SSPX1324.jpg now with the rockers repaired , I was able to get the cab height finalized @ 9" from the rockers to the Ground . + I also started on the cab mounts Because there are only going to be 4 mounts instead of 6 , I wanted to make sure there were going to be strong . cut out some 3/16" plate and surrounded it with some tube http://i76.photobucket.com/albums/j2...d/SSPX1326.jpg Tacked into place I will add some more supports later , when I turn the frame over . http://i76.photobucket.com/albums/j2...d/SSPX1327.jpg 1 more front frame mount tomorrow , then I can get on the front cab mount . |
Looking good. What are using for a tube bender?
I bought a magnum bender , it's a "manual" bender , just like the JD2 bender . KMS tools had a big sale and I got a super deal , includuding 3 dies .. I just couldnt pass it up
and cab side mount
Bent up some 1/2" solid stock with the 3/16" plate . as well as a "fish plate" for the cab side , 1/2" stock actually goes threw the fish plate for a stronger "plug" weld , and a toyota stock body mount bushing , I now have the front mounted http://i76.photobucket.com/albums/j2...d/SSPX1328.jpg http://i76.photobucket.com/albums/j2...d/SSPX1331.jpg and now the front of the cab is mounted still have some supports and final welding to do when I can turn over the frame , but for now it's good to go also .. the cab now has it final "stance" http://i76.photobucket.com/albums/j2...d/SSPX1329.jpg http://i76.photobucket.com/albums/j2...d/SSPX1330.jpg acetone can for referance .... . |
ok .. so I had a "peek" at the beginnings of this thread , and it didnt really start from day 1
so I'm going to refresh and let you all know the start of the build . The build started with the stock truck which I had rebuilt the 22RE engine http://www.members.shaw.ca/slacker50...s/IM000492.JPG although a great engine , it just wasnt what I wanted anymore .. so , I bought a Supra http://www.members.shaw.ca/slacker502/IM001042.JPG and "gutted " it http://www.members.shaw.ca/slacker502/IM001113.JPG . |
