Toyotafiberglass - Supertoy
i'm building a FULL out 350HP custom .. and wonder if there is anybody else ??
here's mine . http://www.members.shaw.ca/slacker50...s/IM000600.JPG |
ya i've got interest in 'em. i like what i see there.
I have a 93 that I'am stuffing a 2uzfe motor in.
James |
NICE
I would like to do to same basic project but not done with 4x4 yet good work post E.T.s when you get some. |
not to take away from this site .. but for those of you interested >>>
2wd board specific .. http://toyota2wd.proboards2.com/index.cgi |
Hells yeah dude!!!!!
i hope your putting a 350 in it and like slamming it or somthing. Because weight and pre running dont mix.
I have a 7M-GTE going in , as well as full custom frame , including supra front IFS , and REAR IRS ..
http://www.members.shaw.ca/slacker502/IM001576.JPG |
Wow!! You got quite a ride there Corey! Hope you weight down that rear end (PUT SOME JUNK IN YER TRUNK) to keep the tires hooked up and not get loose on you!
Are you going to be running twin's on it? NOS? I think you should donate that there engine to my 4 Runner project!! ;) :D John |
no twins .. just single .. 350 ~ 400 should be enough ..
it's a big project , and have a couple of years into it already .. and a few more to go as well :) |
NEW custom frame is comming along ..
SUPERTOY is almost a roller :) http://www.members.shaw.ca/slacker502/supertoy.jpg http://www.members.shaw.ca/slacker502/supertoy%201.jpg :lol: |
Awesome! I want to do the same thing but with an older truck like a 77 or something(First gen 4x4 body style).
2wd
can you name name a better 2wd
ive owned three of them 87-88's have great lines. try to get a smooth side bed from a 4wd. |
not a chance ..
I'm going with a totally CUSTOM look .. not a bagger http://www.toyotafiberglass.com/IM001120.JPG is the bed , and matching fronts .. http://www.toyotafiberglass.com/IM001597.JPG rear street slicks about 2' wide .. wide fronts .. you aint seen notin' yet . :shocked: |
how about a awd first gen 4rnnr with a 350 sbc
Originally Posted by 4bytruckin
(Post 50558501)
still in the "what if" file. i want to custom my runner but i'm not sure which direction. if i did i'd use a lt1 with a 383 strocker kit and decked heads. 750 cfm demon carb with nitrous plate. 4o8ole with clocked awd trasnfer case from a typhoon. lsd in front and rear . typhoon case allows for a 70/30 power split to the rear. lower the suspension about three inches or so. it's just one option. other would be a 6.6 duramax and dana 60's front and rear
sounds cool .
hey Corey:
First time I checked out your super truck build, I like it...doubt my wife will let me have two at once though...have fun with it.. |
Tks Robb .. I'm excited to finally get a rolling chassis .. it's been a long term project .
| All times are GMT -8. The time now is 10:09 PM. |
