theres a trekker for sale in toronto
http://toronto.kijiji.ca/c-cars-vehi...QAdIdZ80507814
if i had the money id go offer him 1500 for everything
so with the floor now cut out ..
I started to cut out the rest of the rust ....
VERY happy with the out side rockers , no rust at all !
so I have now started building it back up ..
couple of small pieces .
Quote:
I wish you could head down here for a cab. They come up all the time. Last week I saw 3 good cabs in the junkyard....not sure about getting one north of the border though.
I'd drive down in a second .. I'm not that far away .. BUT theOriginally Posted by ocdropzone
Corey:I wish you could head down here for a cab. They come up all the time. Last week I saw 3 good cabs in the junkyard....not sure about getting one north of the border though.
thing is .. I want the factory sun roof .. thats the issue ..
a couple questions...what do you use to acid dip? how long do you dip it?
what do you use to zinc coat? is it a spray can style?
how resilient is the por-15 to rock and metal knicks compared to spray paint?
i have been woundering the same thing, cause i plan on doing this stuff to my 82 p/u 4x4 soonOriginally Posted by idayota
a couple questions...what do you use to acid dip? how long do you dip it?what do you use to zinc coat? is it a spray can style?
acid is hydrafloric .. you can get it threw any auto detail supply company .. depending on the mix , ( I mix ~10:1 ) and the size piece your dipping , sometimes 1/2 hour , to overnight .. works great .
wahs with water , and dry , and zinc right away . The zinc chromate is "weld threw primer" avaliable at any welding supply , or auto parts store , and it's the best primer for bare metal there is .and yes rattle can .
POR is a rust treatment .. depending on the way you apply , is the "reziliant " coating you will get . I suggest reading the info on there site .
thanks for the heads up. i've read through por-15's material on their site a couple times over the last couple months. i understand its rust preventative properties, i was just curious in your experience on how well it adheres to parts (i.e. frame, axles, springs, etc). you're using it everywhere, so you must like the stuff for longevity...from that would it be safe to infer that it adheres pretty well?
I guess I should be more carefull about answering peoples questions about stuff like that .. sometimes I forget not all have experiance using chemicals ..
this stuff is DANGEROUS ... and upmost care should be taken in handeling , this is shop use only stuff .
protective clothing , as well as resperator MUST BE USED !
ABSOLUTLY ..
like I said .. sometimes I forget "were not all profesionals"
for heavens sake .. it's ACID .. handle with care
got a bit more done today .. sandblasted the inside of the rocker , and zinc'd ..
also got the seatbelt rienforcements in place ..
and with all the pieces now cut out , I started to weld er' all together
just have to "dress" the spot welds and one side is ready for the floor
Thanks Bro .. I'm defenatly wanting it to last another 20 + years for sure ..
did a couple of hours tonight .. got the cab mounts bent up , and welded ..
and kind of what they will look like ....
also . did a little more cab repair ..
welded in a new little patch ...
cut out the new piece , sand blasted ther inside , and zinc'd ... and welded .
thanks guys ..
wee bit more today .. was able to cut the inner rocker off of the other side , inbetween jobs in the shop .
have a customer comming to pick up his 4runner tomorrow https://www.yotatech.com/forums/f116...-build-156071/ so I might get somemore done .. duno !
Looking great Corey!
I can't wait to see this thing when it's done.
Originally Posted by shaw_j
Looking great Corey!I can't wait to see this thing when it's done.
Thanks .. me too .
Quote:
i really do though
Originally Posted by scuba
finish already !!! i wanna see that thing sling some mud !!
i really do though
still have a LONG way to go before I'm "slingin' " mud ...
not sure if you were still looking for the supercharger but i found one on CL while i was doing my nighly run down of everywhere in cali http://santabarbara.craigslist.org/pts/900241010.html
