okay, so i made another similar post, but this one is a little different. i want to get my 4x4 sr5 4runner lifted, and it seems revtek/cornfed are the best way to go for a suspension lift. some say get the same size for front and rear, but i called cornfed and the guy said it's better to get 2.5in for front and 2 for rear.
does getting a suspension and body lift create any maintenance problems? and what's the best way to get a body lift, as in who makes the best body lift. links to any webpages on this? right now i'm not lookig to get new springs or anything extra, just the lift(s). maybe some swaybar disconnects later tho.
i really like the way the white 4runner on the cornfed page looks (see below). i was told that has a 3 inch body and 3 inch suspension lift.
so many choices....
so many choices....
Guest
If you want the best lift get the SAWs upfront and Downey coils in the rear with Bilstein shocks in the rear. It is expensive but it is the best lift.
Quote:
All he sells is a 2" rear spacer. He does not make a 2.5" so he can't sell you one. Daystar makes a 2.5" rear spacer whick is fine, but for a few dollars more get the Downey springs. Much more bang for you buck.Originally posted by calrockx
