and yha it should fit . i got a 3inch body lift and the manifold has a 1inch space if any thing i can take off 1 inch lol
where can i find +12 Volts from Ignition Switch (Hot in Run and Start) in my truck??? help any one??
Well cant tell if you have power going to the main fuse block but there is switched power /run power at the old ecm location. From the spaghetti mess of wires i cant tell but it is in there. It was in a white connector that had a bunch of male blade connectors inside it, i believe 4 large blades and about 20 smaller ones. It was one of the large blade connectors inside that plug. I think its the connector that under all the stray wires.
Constant 12v White and White/Red
Starter Black Ignition Black/Yellow Ignition 2 Black/Red I tagged all my wires from the ignition harness because I installed my relay bank behind the glove box, you might find it easire to get your wires from the fuse block under the hood.. They should all be there, same color... |
Originally Posted by yotaman107
(Post 51622494)
Starter Black Ignition Black/Yellow Ignition 2 Black/Red I tagged all my wires from the ignition harness because I installed my relay bank behind the glove box, you might find it easire to get your wires from the fuse block under the hood.. They should all be there, same color... yota man you are the best !! exacly what i was looking for!! |
Originally Posted by GonOvr
(Post 51622169)
well my goals are to eliminate the fuse box from the front but yha you are right because the air mass senser do have what i em looking for |
1 Attachment(s)
If you dont already have this info it may come in handy if you decide to keep all your factory gauges working with the 5.0..
(Post 51624765)
omg you are the best in the how yota world ! lol:bowdown2:i was hella looking for it ... |
whats up with this swap .. you done yet :) call me , i lost your number wanna come check it out .
Originally Posted by RMA
(Post 51630410)
ill call you .. ill be busy in the morning and some of the afternoon tomorrow.. but maybe late in the afternoon ..
i have a small welding job in the morning.. and i broke my rear window on my 2wd camper today , have to get that fixed before it starts to rain again. |
(Post 51630435)
