95 4runner, put in an aftermarket radio now I have no dash lights, dimmer switch only turns on the headlights, no tail lights either
seperate issue, 15 amp fuse for rear anti lock was blown, replaced it now the dash light for the rear anti lock is on
I'm 15 and this is my first vehicle, could use some help
Look for another blown fuse under the hood or in the box under the steering wheel/kick panel etc.
You did not accidently leave a plug disconnected under the dash somehow?
I dont think so, i only removed the lower dash panels. I checked the fuses under the hood, and under the dash, none blown that i can see. Apparently, the rear anti-lock fuse was an issue with the previous owner because i found a little fuse container in the glove box full of 15 amp fuses, so im not sure whats going on with that.
Did you plug into the Toyota radio harness or did you cut that off and make a mess of things.
It could be possible if you did that you have something wired wrong.
Just how did you do this.
