YotaTech Forums
-   General Vehicle Related Topics (Non Year Related) (https://www.yotatech.com/forums/f123/)
-   -   Interior Door Panel (https://www.yotatech.com/forums/f123/interior-door-panel-319999/)
Sumuno May 22, 2025 09:02 AM
Interior Door Panel
I am looking at replacing the material on inside of doors, getting dirty and ungluiing from panel. I removed the panel and on the backside there is what looks like plastic rivets holding the pieces together. Is there a way to remove these and then how do i put them back on. They look like melted plastic done from factory.
RAD4Runner May 27, 2025 07:06 PM
In case you want to simplify fasteners and make it easier to remove and re-install inner door panels in the future, here's how I replaced my door panel covering and fasteners:
https://www.yotatech.com/forums/f199...l#post52301403
Sumuno May 28, 2025 08:10 AM
Was asking about these types of plastic rivets that hold the upholstered part of the door interior
https://cimg4.ibsrv.net/gimg/www.yot...fc3793e09.jpeg
RAD4Runner May 28, 2025 10:23 AM
AAH! You have a newer model. Sorry, I thought you had an older model.
Discombobulated May 28, 2025 01:56 PM
This looks promising and makes sense:
You could also use an epoxy to re-create the original plastic rivet if you wanted but some correct length screws should work depending on how deep the hole is.
Sumuno May 28, 2025 02:18 PM
Originally Posted by rad4runner (Post 52501418)
aah! You have a newer model. Sorry, i thought you had an older model.
93’ sr5
Sumuno May 28, 2025 02:21 PM
https://m.youtube.com/watch?v=CnciDz...BwYW5lbA%3D%3D
That looks like it would work, i would be afraid with the age the plastic might crack putting screws in. But i could always heat up screw first and kind of melt its way i. making threads. Thanks
prcnctoyo May 29, 2025 02:09 AM
Maybe the parts are still available. Check out the link below. You can change the year/model/frame code/char by clicking in the boxes near the top. If you click on a 5 digit code a popup will give you the 10 digit part #.
For example 67772E is part # 67772-16020 and is still available.
https://japan-parts.eu/toyota/us/199...glass/2#67772E
Sumuno May 29, 2025 06:53 AM
Thanks for the info but those parts not available but great site to look up parts
prcnctoyo May 30, 2025 12:56 PM
Part # 67772-16020 is still available. It's showing a price on my local toyota parts site so that means it's still available.
https://autoparts.fredandersontoyota...ry=67772-16020
