4:88's and 33's, gets me where I need to go on/off road.
35/12.50/R15s on stock 4.10s... I'm getting 5.29s thought
33x12.5/15 w/ stock 4:56's debating to go up to 4:88s after the 3.4 is in...
33x10.5-15 BFG A/Ts with stock 4.10s. the 88 22RE, even with it's second rebuild, cannot maintain speed on a hill.
on highways, i drive it floored in 4th. on a downhill it goes up to 70-75 at 4k. on an uphill it drops to 50-55 at 28k. then i gotta shift to 3rd. 5th is hibernating until i get 4.88s or 5.29s |
Im running 36in military tires with stock 4.10s with a 22re and manual tranny... needless to say I never use 5th gear:saw:
88' 22RE 5spd
ALL on 31X10.50 R15 Was on OE 4.10's Just swapped to 4.56 from ADD v6 auto prior to the swap, hills were a loosing battle hills now, acceleration is easy in 5th with traffic |
22re, 5speed, 5.29s and 37s, a little slow, but she will go 70 on the freeway
4.3v6 d44 513s d60 513s smokes 37s
31x10.50 on stock rims and stock gears auto tranny and it's slow realy slow :(
what would you guys recomend for gears?????? any help i use it on the freeway 80% of the time it's a lovely 22re efi |
4:88's would help a bunch tacho!
5.29's would help more for the auto if you go to 33's lol
might as well go with 5:71's and step up to 35's :l
Might as well do an engine swap, lift it 6"s, put in 5.71s, and get some 37" tires. No really, 4.88s and 31s with a 22re should be perfect or 5.29s with 33s like camo said.
Originally Posted by TOYOTA 1
(Post 51303287)
Now if only Tippy Ran.... :shrug: |
33's with stock 4.10 a little sluggish on acceleration. otherwise it behaves very nicely
33x12.5 with 4.88 little slow up here at 5000 to 7000ft but I can almost go 80 on the highway so long as I don't hit any hills. I'll probably go down to a 10.5 tire to reduce rotating mass and hopefully liven things up a bit.
86 4x4 22re 5spd, 5.29's and 30x9.50R-15's.
According to the radar sign, when my speedo says 70mph, I'm actually going 55. 55mph = 3000 rpm right now I don't notice hills, up or down lol |
95- 35s, 4.10s
85- stock puney tires, 4.10s= speed demon |
1980 4x4, bone stock 20r, 4spd.
running 30x9.50 Dunlop mud terrains with the stock 4.38 gears. |
85 rebuilt 22r 5.29's spooled with 35.14.5 .15 new meats!
