i live in south florida, and there aren't any hills, but we got alot of water, and alot of bridges. there's 4 major bridges in my area, and about 5 or 6 that i travel across normally. i got a question for you hillbillies out there
i notice sometimes when cruising in 5th, and going over the bridge the truck starts to slow down, i usually down shift to 4th on the incline and then shift back to 5th when i get to the top. is that the right way to do it? am i overthinking it?
BTW: the hillbillies statement wasn't meant to be offensive, we like to be called swampbillies down here in florida
....i notice sometimes when cruising in 5th, and going over the bridge the truck starts to slow down, i usually down shift to 4th on the incline and then shift back to 5th when i get to the top. is that the right way to do it? am i overthinking it?
only with 31's...haha
...the 213's i got on now will go 90 in 5th up a hill
edit: maybe 85...im dreaming...
well... luckily i drive some pretty steep roads. I drive around a 20% grade daily, and find that to get up it, i cruise at 55 at the bottom, downshift to fourth, get up to 60 at the bottom, floor it up the hill, and make it goin 50 at the top. If i drop below 50, i have to drop it to 3rd and floor it. If you're going 70+ at the bottom of the hill, you should have no problem going up in 5th gear. I find that in my truck, 2nd gear is the most versatile, and for super steep hills, is the best when going less than 35.
If I didn`t have any real hills to climb I would let my mind work.
I would use 2nd gear low range just for practice . Going down the other side even slower.
