Every Clutch I change gets new Hydraulics as well I guess I should have stated that as well.
Why people install a new clutch without them go figure. |
Well didn't get to it last night gonna go tackle it today, I'd it normal on the 90 model 2wd pickups for the transmission cross member to be welded in and it looks welded from factory theres no bolt holes
2wd is really different then a 4x4 you could be correct but it would be a pain to get the transmission out.
Never been under one. |
Well new clutch,pilot bearing and hub, new pivot ball, clutch master cylinder, slave cylinder, hydraulic hose, new hard line, new trans oil, and shifter seat clutch now works properly and goes into gear still waiting for new bushing so still alot of play but all in all operates pretty good
