4th gen sub box build (pics)
I was bored today because it's my weekend (mon-tues) so I decided I would try my hand at building a custom box for my runner. I have wanted to have something like this since I got her. I like the sleekness of the JL stealthbox but refuse to overpay for it, especially since I already have the sub and you can't just buy the enclosure.
I got the idea from someone on here that built a similar box but I never got the dimensions so I decided to just kind of wing it. I figure since I had 2 sheets of 3' x 4', 3/4" MDF left over from building my workbench in my new house I can't go wrong. NONE of these are by any means precise dimensions, but its what I tried. I dont know how it will work out. I decided the entire width would be about 7" wide. So I started by cutting a few strips to be 5 1/2" wide. See pic for lengths. http://img.photobucket.com/albums/v5...dimensions.jpg I just cut one piece after another and test fitted them. Some of the angles didnt end up being how I had intended, but I think it will work out ok. http://img.photobucket.com/albums/v5...ner/angles.jpg Here's a pic of the old box I am attempting to upgrade from, mostly to save useable space for other junk: http://img.photobucket.com/albums/v5...ner/oldbox.jpg I honestly have no idea what the interior volume of the new (attempted) box will be. Hopefully it will sound good. This is as far as I got today, I will continue working on it tuesday and post what else I have finished. Also, here is some pics of how I mounted my amp under the front passenger seat. I would say it took me 5-6 hours. I was in no rush and had the day off. Because of how the 4th gen runners have the rear foot vent I decided to mount the amp on some 2x2 wood to make room for air to flow underneath. Due to limited wood on hand I actually used one piece of 2x2 on one side and 2 pieces of 1x2 on the other side. http://img.photobucket.com/albums/v5...unner/amp1.jpg a closer look http://img.photobucket.com/albums/v5...unner/amp2.jpg I ran 4 gauge wire to the amp because I plan to add another amp for the aftermarket speakers I will add someday. Never hurts to plan ahead. Here's how I ran the power cable for now. I mounted the amp fuse to the top of the fuse box. Just seemed like an easy place to put it. http://img.photobucket.com/albums/v5...pfusemount.jpg Heres where I ran it into the car. http://img.photobucket.com/albums/v5...r/firewall.jpg Here's the inside of where it came into the car. http://img.photobucket.com/albums/v5...werintocar.jpg Here's (roughly) the route where I ran the power cable: http://img.photobucket.com/albums/v5...powerroute.jpg I ran the cable down the center console and out the other side under the carpet to under the passenger seat. It was a PITA to get all the wires(4ga power, 4ga ground, turn on lead, interconnect) under the plastic and carpet and wasnt in the mood to take pics of that tho. Anyhow, I will post tomorrow about how the rest of the new box build goes. |
good stuff ... nice documentation too. Keep us updated
Thanks, I finished the box and put the sub in it today. It sounds good, probably not quite as boomy as the original box was, but i only listened to it for about 10 minutes so. All i need to do now is get some gray carpet to match the rest and figure out exactly how i am going to anchor the whole thing in to keep it secure. Ill post a few more pics later.
So here are some more pics:
I sealed the box with some silicone sealant http://img.photobucket.com/albums/v5...ner/sealed.jpg Here is where i mounted the terminal for the speaker. Its along the part that goes down the back of the wheel well. http://img.photobucket.com/albums/v5...r/terminal.jpg Here is what it looks like in the car, the rope around it is just temporary. Although it does hold it in quite nicely. http://img.photobucket.com/albums/v5...r/boxincar.jpg About the cover fitting, here is a pic of it under the bar http://img.photobucket.com/albums/v5...ner/cover1.jpg and a pic of it where it hits http://img.photobucket.com/albums/v5...ner/cover2.jpg It doesnt hit so bad that i am worried about it, i kinda wish i had noticed this during construction but i didnt, so ˟˟˟˟˟˟ it. The reason it is notched on the backside is so i can still ge to the outlet if i need to http://img.photobucket.com/albums/v5.../powerplug.jpg I am still working on how i am going to anchor it. I will go to the hardware store and see what i can find to do the trick. As soon as i get some carpet for it I'll post pics of the final product. |
Here is a picture of the final project
http://img.photobucket.com/albums/v5...r/finished.jpg Here is how the cover hits a bit but is still easy to close http://img.photobucket.com/albums/v5...rfinished1.jpg and here is how i have it mounted in right now. A couple of little d-ring type hanging brackets and some mini-bungee cords. It makes it easy to take out if i need to. And i dont have a problem with it moving/rattling at all. http://img.photobucket.com/albums/v5...ner/mount2.jpg http://img.photobucket.com/albums/v5...ner/mount1.jpg |
Looks good man, congrats!
