javascript links & dropdowns not working
I don't know if anyone has brought this to the attention of the admins or not, so I decided to make a thread.
While in threads the search, blogs, Helpful Links, member profile and all other links w/dropdowns do not work. While in the Forum indexes all is well. This only happens when in the actual threads. While logged in none work. While logged out the profile link works but not the dropdown with the "PM" etc etc options work, but not any other links/dropdowns. Also noticed the "Remove Text Formatting" Button also doesn't work at all either. I has in the past. FIREFOX 3.6.13 & IE8 on WIN7 confirmed. Have not tried Chrome or Opera. Not sure how long it's been like that though. I would say maybe a week. Thanks. |
i thought it was me.....was waiting for someone to post "The search button doesn't work" which we know the ability to use said button just isn't there either.
but truthfully....sometimes it did, sometimes it didn't....same thing w/ PM-ing......I know Swimmerboy had an issue and LUMPY and I were PM-ing just fine, but I could not click on YOUR profile....so again, thought it was me. |
it is a known issue...it popped up about a week ago. Working on getting it fixed.
One work around we found (doesn't always work) it is to go to: >user CP on left side you will see 'settings and options' select 'edit options' down at the bottom of the page you will see 'Miscellaneous Options ' under 'Forum skin' there is several options for appearance if you try ----Yotatech Extreme w/mud **Don't select a format with sizeable fonts** it might bring your tool bar options back like search. Corey found that work around and it worked for me The Tech Guys are trying to figure out what happened. It knocked out a lot of the mods too... |
I was using the same template just with the "sizable fonts" option. Have just changed to the one without the sizable fonts and all of the dropdowns including the profile pm drop down now work.
cool, appears the glitch is the sizeable fonts..added that tidbit to the work around post, forgot about it
Glad you are back in action:bigok: |
I guess this workaround post is only available to the mods? Glad I started this thread then lol.
BTW the "remove text formatting" button appears to work now too. |
I got messing around the other day and discovered it was the sizable fonts one with the extreme background jpg.
Figures, as that is the only theme I use. Text is to small for me with a non sizable fonts theme. I upped the text via Firefox, but it does not loom as good. If I remember the original theme with sizable fonts will work, but I like the darker extreme theme much better. So much that my personal home page mimicks it. I am sure tech will get it solved before to long. |
PS, I meant extreme sizable fonts/with mud too.
That is my fave. Can not edit post with mobile plugin ;) |
Extreme sizable fonts with no mud background works as well.
Originally Posted by ocdropzone
(Post 51654775)
>user CP on left side you will see 'settings and options' select 'edit options' down at the bottom of the page you will see 'Miscellaneous Options ' under 'Forum skin' there is several options for appearance if you try ----Yotatech Extreme w/mud **Don't select a format with sizeable fonts** it might bring your tool bar options back like search. Corey found that work around and it worked for me The Tech Guys are trying to figure out what happened. It knocked out a lot of the mods too... ocdropzone always making it harder than it really is. hahahahaha. J/K. |
hey man give me a break...I am old and only know how to do somethings one way:D
anyway, the Tech Guys say the issue has been fixed so hopefully no one experiences any other issues... |
yyyyyaaaaaaayyyy It works. :great: Leave it to me to kick some butt and get stuff done around here. hahahaha.
Originally Posted by xxxtreme22r
(Post 51654928)
(Post 51654931)
they were working on it over the weekend Mr. Smarty Pants
hey the search button works.
can we make the search button like 1 inch tall so it gets used more often......as an old guy I even use it |
Originally Posted by 92 TOY
(Post 51654940)
can we make the search button like 1 inch tall so it gets used more often......as an old guy I even use it I have BIG BOLD RED TEXT on the signup page to not create a second account if the fist one does not take, yet they still do. |
XXX(AKA; OG-B, IN THE PLACE TO Be!) FTW! LOL.
YAY, it works, .....don't have to THINK, just point and press, YAY! hahaha. |
I find that I can't use IE8 or Firefox to view the site when logged in, the page will load, but as soon as I login, I get a blank page in firefox, or an error page with IE, Chrome however works fine. Not sure whats up unless the recent java update killed everything.
working fine for me all night, firefox 3.6.13 on win 7.
(Post 51662456)
| All times are GMT -8. The time now is 12:26 AM. |
