Automatic behind 22R?
Anybody know how to swap an automatic behind a 22R engine? I'm thinking like a TH-350 or Ford C-4. I think I've seen a Powerglide trans as well, but that was with an Atlas. The stuff I've been climbing lately, an auto would make easier and less dangerous when I don't make it.
Any constructive advice would be appreicated. Let me know. |
Toyota makes an auto for the 22RE, so it should bolt to the 22R. Not sure on the electronics though.
Just my $.02. :D |
My FSM manual has diagrams showing a 22R carb with a dashpot for an auto trans.
These links will get ya started on some possibilities for Toyota or other.
http://advanceadapters.com/ http://www.marks4wd.com/products/eng...lux-index.html http://www.inchwormgear.com/store/index.php?cPath=45 http://www.inchwormgear.com/store/index.php?cPath=21 These are Toyota transmission/transfer case info. http://www.4x4wire.com/toyota/faq/parts/ http://en.wikipedia.org/wiki/Categor..._transmissions |
Por que... por que!
Inchworm Gear sells an adapter to run a late model automatic to the early, geardrive T-case. This should do the trick!
They also have an adaptor to use your tranny and t-case with gear drive cases. Look a little farther down the page.
Already have a gear drive case. Read the post.
