Originally Posted by Intrepid
(Post 50340278)
For the rear, lose the overload or cut it down to a block, put in a long AAL and lose the block, it will give you some lift and let you flex more than the overload will whole.
What are you running for a shackle in the back? You could possibly put a longer shackle in if you needed more height after that. You are going to have to do something about that front shackle angle, that is horrible. Maybe you can make some sort of a new shackle hanger farther forwards or something. Otherwise, sell those TG springs, build yourself some rears up front out of 51" yota rears and that should give you enough length to get your shackle right and keep the axle forwards. I agree that you may need some trimming, it isn't the regular driving that will be a problem it will be when you are flexed...otherwise perhaps some bumpstoppage is in order. |
AAL= add a leaf
I gave up caring what the neighbors thought along time ago...........Besides I was the first to build here, so the can kiss my arse!! Here is my other rig that they have to look at constantly. |
Dude, shackle length is not going to help the front angle. You need longer springs, or the hanger has to be moved.
Originally Posted by Flygtenstein
(Post 50340855)
I would look at a rear AAL, LONG.. and loosing the blocks with whatever shacke leanght it take... |
(Post 50340855)
For the AAL, look for a long AAL that gives about 2" of lift, it will really help you out and it will flex better. With that overload in there, I bet your tire won't stuff well at all. |
(Post 50340904)
Exactly.
Here are some flex pics taken behind a neighbors house, we don't have any hills around here:cry2:
http://i41.photobucket.com/albums/e2...4runner099.jpg http://i41.photobucket.com/albums/e2...4runner100.jpg http://i41.photobucket.com/albums/e2...4runner098.jpg Not much room around the tire http://i41.photobucket.com/albums/e2...4runner102.jpg |
Good job on your build. As other have posted, those front shackles look pretty rough. Glad you are taking care of it. I noticed in the 3rd pic you're still missing your front D-shaft, gonna get a long travel slip yoke?
Good job. |
Looks pretty good, with a propper shackle angle up fron you could get that front to drop a lot further... and if you remove the 3" block in the rear your going to need bumpstops for sure... But bumpstops are a good thing as they actually help flex. It also looks like your shocks are limiting the rear drown travel....
Originally Posted by AH64ID
(Post 50341426)
If shocks are your limiting factor the tire should end up in the same location, with or with/out block..
I love that front invisa-shaft. How much it cost you? :lol: In all seriousness, that is an awesome 4Runner and I would try something similar if I had the money.
here is a shot of the rear spring compressed, looks bottomed out to me. Hell...... it might be bottomed out too. I need to run the numbers on the shocks.
http://i41.photobucket.com/albums/e2...unner104-1.jpg |
Originally Posted by 91_4x4runner
(Post 50341453)
I know most /\ setups have a little steeper angle on them.. I use 13" travel ranchos and have never bottomed out or compressed all the way... But my springs are too stiff and they were the limiting factor on droop...
best one I could find... http://i79.photobucket.com/albums/j1...uckWork005.jpg |
I'm not really building the ultimate rock crawler....just want to be able to go just about anywhere I want, so if it doesn't flex out completely than that's OK with me. My old 85 had alot less flex than this and it went everywhere I pointed it.
Wow I havent been around this board in a long time. Its nice to see your truck is evolving. From one big 2nd gen runner to another. Are you having issues with axle wrap? I sure am!!
I can only speculate that I will have major axle wrap as it sits today (3" blocks) Trying to get em out of there!! 4rnr.......What set up do you have?
Why not build a trackbar? This is what I have for my rear setup. Works very well in getting the torque to the ground.....
