lighting issue
1982 toyota pu 4x4 front lights all work dash lights work,Tail lights work but the brake passenger side signal or either hazard on the rear don't work ?
Any help appreciated !
Ok, so you are saying that only the rear passenger side turn signal does not work, did you pull the bulb and check it? Sometimes you can visually see that the filament is broken, but if it looks ok, you can swap it to the other side and see what that does.
| All times are GMT -8. The time now is 02:50 AM. |
