Ring gear pattern help - 07 Tundra - 10.5" rear - Nitro gears
Hi,
I have been working with installing my new gear set and I would like some opinions on my gear pattern. The backlash: 0.00551181102 inches (0.14mm) Pinon bearing preload - 19-20 lb.ft + 1-2 ft.lb for carrier bearing preload Pinion shim: 0.0511811024 inches For me the drive seems ok, but I can't figure out the coast. Is it a bit to much towards the top? If I need to change depth shim it would be nice If you recommend if i add or take of some as the terms is a bit confusing for me yet:) https://cimg5.ibsrv.net/gimg/www.yot...e68f4507b9.jpg https://cimg6.ibsrv.net/gimg/www.yot...0ae7f3a02b.jpg https://cimg7.ibsrv.net/gimg/www.yot...753a5a951d.jpg https://cimg8.ibsrv.net/gimg/www.yot...235749f888.jpg |
The backlash is more than .5 inch? Hoefully zuk can comment on the pattern.
My mistake, I wrote wrong when converting. Will edit the post.
The backlash is 0.14 millimeters = 0.00551181102 inches (The factory manual states: Standard backlash: 0.10 to 0.20 mm (0.00394 to 0.00788 in.) |
check out Zuk's site gearinstalls.com for some examples
I have been to his site earlier, and it is a lot of good and well documented builds there. Thanks for sharing again:)
I think I need to add a thicker shim when reading trough his builds, so I will pull it apart again tomorrow and try. Bought a whole lot off oem shims, hopefully I have what i need. Any opinions on the pattern now be a big help, so I do not need to pull it apart to many times. |
Update
Update, after reading trough the builds on gearinnstalls I had a new go at it.
I did change the pinion shim to make it shallower: New data: Backlash: 0.00787401575 inches (0.20mm) Pinon bearing preload - 10 ft.lbs (To be easier to turn) Pinion shim: 0.0482283465 inches (from 0.0511811024) In my opinion it looks better now. I think I will finish it and run like this if not anybody see something way off. https://cimg4.ibsrv.net/gimg/www.yot...d3b34b5cf2.jpg https://cimg6.ibsrv.net/gimg/www.yot...0ca65d2879.jpg https://cimg9.ibsrv.net/gimg/www.yot...6a0974c7ae.jpg https://cimg3.ibsrv.net/gimg/www.yot...c771576372.jpg https://cimg1.ibsrv.net/gimg/www.yot...fddf40b77e.jpg https://cimg0.ibsrv.net/gimg/www.yot...5012c0a67b.jpg |
https://cimg3.ibsrv.net/gimg/www.yot...f7ae6b0c34.jpg
Originally Posted by janliseth
(Post 52425044)
Thank you for taking your time, really appreciate it:)
Have a nice vacation on the Cayman Islands, looks like a lovely place to be:) |
