How much lift?
I had a guy sell 4 new Firestone destination m/t 285/75/16 for 200.00(he runs a huge tire chain). I want to know if a 3" lift will do?
Yep 2.5" will do the trick.
yep, everything say's "these tires will fit with minor trimming." Well with major trimming, how big could you go?
what kind of rims will work to off set? I dont want anything fancey, they are just going to get banged up.
You can fit any size tire if you set your mind to it.
i have a 2000 4runner Ltd...would i have to do any trimming to fit 33's on a 2.5 inch lift?? Because the limited flares would complicate that i would think
Yep.. I'm doing a 2.5 ToyTec on a 99 runner and putting on 285.70.16's on it for a customer.. will work and look geat..
I know your thread is old but you dont need to trim, I added a 3" toytec lift but when its jacked up off the groung it rubs upper control arm, when set on ground it clears.
