1996 t100 4x4 work in progress
here is my 96 t100 Got the blazeland long travel kit with fox 2.0 RR coilovers 600lb springs, 50/60 valving. Deaver mini pack is installed now. 2.5 piggyback internal bypass shocks off a Raptor. Its got front and rear lockers 4.88 gears 33x1250x15s manual hubs, 1/4 inch steal reinforced frame and a trussed rear axle with aftermarket driveshaft with a disconnect for being flat towed. (BUT I cut off the front hardware to tow it) The shiny metal stubs sticking out of the bed are for a camper (which i no longer have) and are attached to the frame. Custom 32 gallon tank along with the extra aprox. 25-30 gallon tank not installed.
http://i1234.photobucket.com/albums/...cf8f6a6266.jpg http://i1234.photobucket.com/albums/...8ca57aaaf7.jpg These images by JMalherbe http://i1234.photobucket.com/albums/...3-13161901.jpg Rear drive shaft disconnect http://i1234.photobucket.com/albums/...-131618172.jpg http://i1234.photobucket.com/albums/...3-13161756.jpg Front recievers http://i1234.photobucket.com/albums/...3-13161731.jpg Reinforced frame at the bed into cab about 3 feet long. http://i1234.photobucket.com/albums/...3-13161706.jpg trussed rear end no axillary gas tank right now. http://i1234.photobucket.com/albums/...-131656342.jpg http://[IMG]http://i1234.photobucket...cf8f6a6266.jpghttps://www.yotatech.com/[IMG]http:/...cf8f6a6266.jpg |
Im ordering my coilovers today 8.5 fox 2.0 RR.
sounds like a good build cant wait to see the finished product
hey i have the same exact truck (except all the addons) even the same tires and rims but i was wondering if i could get a three inc lift outa my tortion bars and if you think thats even a good idea
I'm maxed out with the lift from my torsion bars. You can't get 3 I'm already very close to my upper bump stops. I broke my femur and the build is on hold but ill be getting it going again soon I hope.
Had to hammer my wheel wells and cut the bottom tube of my bumper to fit 33x1250s. If you have the same tires then your maxed also. You can't get more lift out of after market bars than stock bars. The geometry doesn't change. Just the spring rate.
true and yeah all i have is a 3 inch body and the tires rub but not horrible i can still make a tight u turn but eventually i wanna straight axel it and get a twin turbo deisle and some 37s
any pics of it finished?
Broke my leg pretty bad last year so this project came to a screeching halt. But I just got the blazeland kit today so I will be updating with pics as the build comes along.
Only a few more days untill Blazeland kit is finished.. cant sleep. last part comes on tuesday.
Blazeland complete!
Full extension on bumps.
http://i1234.photobucket.com/albums/...k/IMAG0267.jpg On lower bump stops http://i1234.photobucket.com/albums/...k/IMAG0268.jpg These are before i set my alignment. Tons of travel. right now i have the ride height set even with the back. I might set it a little higher in preparation of figuring out the back end. I got a hold of a set of fox 2.5 internal bypass piggyback shocks off of a ford Raptor. Those plus a Deaver mini pack is my plan for the rear. Will post more pics when i get a chance to test it out! |
ride height for now
might raise it another inch. getting glass soon.
http://i1234.photobucket.com/albums/...07925609_o.jpg |
SOON! deaver mini pack and fox 2.5 piggyback internal bypasses off of a ford raptor. Anyone know about making bed a bed cage? I only need to raise my shock mount about 5 inches and I want to keep as much room as possible.
http://i1234.photobucket.com/albums/...k/IMAG0285.jpg |
Hey Z what front axels are you running. Since Nate says to use T-100 axels? trucks looks good.
Thanks! I am using the custom axles Total Chaos made for the t100 for use with the TC kit, also works for Blazeland. $600 later They are a huge pain in the ass to install, they are machined to be a crazy tight fit. Had to freeze them to get them into the CVs.
Holy 600 hundo. Well I guess you have no other choice. Dang.
Ya Just one more cost of keeping 4x4 and the cost of the t100, The redheaded step child of the toyota world.
Freakin awesome. What are you plans for the bed?
