Wierd Stalling problem....WTF???
I have a 98 Runner with the 3.4 (47,000 miles)
I have only had it about 6 weeks. Today on the way to work it stalled at a stop light ( I have an AUTO Trans) I didn't notice with the tunes rockin but when i went to take off when the light turned green, I realized my engine had shut off.. I started it... it stalled again.... i restarted it and it kept running..This happened once b4 about 4 weeks ago..I got off the freeway, was at a red light, went to take off and realized it was stalled, that time it started right up and stayed running..I put a can of BG44K in my next tank thinking that might solve the issue and I thought it did, since it hadn't happened again...till today!! Does anyone have any suggestions?? please help me out..thanks :dunno: |
Clogged fuel filter? Since it is intermittent, it sounds like a bad filter or bad gas. Has it had the 30K tuneup?
and don't know if the previous owner had it done.. |
Not that the 30K tuneup is magical, but with only 47K miles on your rig, maybe it was overlooked?
Also check for any vacuum hoses that leak or have become disconnected (sometimes you will hear a hissing sound if it is bad enough). Did you have a CEL? |
Also, make an attempt at obtaining some maintenance information from the dealer you purchased it at. If the previous owner serviced it at the dealer, you may be able to get some information. Make it very clear that you want no personal information from the previous owner, all you want is the maintenance records over the phone, if any.
I have done this on a couple cars, and after some teeth pulling they disclosed the needed info. |
my 98 has done a similar stalling problem.... I can auctauly MAKE it do it...
It happens after a WOT hard accleration, say like, 0-40 like your pulling into traffic, and if you let off, and dont apply any more gas, ( say you get on it, then have to slow down ) as the revs come down its like the idle wont catch it in time and it will rev WAY down ( 200,300rpms ) and just die. usauly takes two attempts to fire it back up, but then runs fine. i just ingore it really cus i figure its a sensor some where. |
It happens after a WOT hard accleration, say like, 0-40 like your pulling into traffic, and if you let off, and dont apply any more gas, ( say you get on it, then have to slow down ) as the revs come down its like the idle wont catch it in time and it will rev WAY down ( 200,300rpms ) and just die. usauly takes two attempts to fire it back up, but then runs fine. i just ingore it really cus i figure its a sensor some where. Everyone else thanks for the input...Anyone think any different knowing its after WOT?? |
I know that it was a one owner, local truck purchased at lew webb toyota in irvine (thanks carfax) so maybe a call to them is in order to try and see if the 30k service was done (thanks to 96_runner)..failing that I might pull a spark plug to inspect it and see if I think they are original or were replaced at 30k ( I should be able to tell right??) If they look hammered I will proceed with the DIY 30k (thanks MTL runner) plus fuel filter (Thanks Sac State) Anyway thanks for all the answers guys..and I am still open to any suggestions or possible solutions.
Does the 3rd gen have an EGR valve as well (not sure.....you never hear about it if there is)? |
[QUOTE=MTL_4runner]You might also check the TPS (throttle position sensor) with a voltmeter and be sure the resistance is within spec according to the FSM (the resistance should change linearly when the butterfly is opened).
That's what went wrong with mine. CEL came on and I kept putting it off since nothing seemed wrong, then it started stalling after I came to a stop. Replaced the TPS sensor and all was good. |
Just a shot
Has it been warm or hot outside, what is the engine temp? When I lived in AZ I had an 84 EFI and it did this to me a few times. Always after WOT or long accelerations and then a stop. It was hot out and the fuel would vaporize in the fuel rail that went over the motor. I put more heat shielding on it and it stopped doing it. Just a shot in the dark. :dunno:
Dude I think it's fixed..
hmmm thats a good idea. mine dosnt do it every often, but I will def look into it. thanks man
