WHo makes these headers???
who makes these?
http://performanceproducts.com/Produ...producttype=20 |
hmm...they have the headers with a hose and without, how do I know which I need?
You need to be more specific on what a "hose" is... If it's part of an EGR or Reed Valve assembly, yes you need it. If it's a crossover pipe, no it isn't necessary as long as you can find an exhaust shop to fabricate one for you.
and how come they dont hae the Xover pipe kit on their website?
$303.91 17410-34AC ‘95-02 3.4 V-6 Header, Auto, Ceramic $409.84 17410-34S ‘95-02 3.4 V-6 Stick (with hose), Chrome $325.17 17410-34SC ‘95-02 3.4 V-6 Stick (with hose), Ceramic $430.96 https://www.downeyoff-road.com/noframes/shim.gif |
I have no idea. My experience was with a 3.0. The 3.4 is an entirely different beast. Should be others here who have those headers who could explain what it is.
I have Downey headers on my 96 4Runner with the 3.4L...
You may wanna check this recent thread for some links and info: https://www.yotatech.com/forums/f2/trd-headers-45586/ I dunno what "the hose" is, but the headers are sold for either an auto or manual tranny, so go by that. |
alright thanks...
umm...hows the installation? What are the torque specs? How do I get to the lower bolts on teh header flange? |
The install sucks. If you read through that thread you'll find my back-story which is basically that I read a lot about how much it sucks before even buying them.
I talked to a local general maintenance/exhaust shop, told them the install sucks, they said they would still do it, I said the install REALLY sucks, "we'll still do it", and they quoted me a flat fee. Okay! With a written estimate in hand, I ordered the headers. They came in about 5 weeks later and I dropped off the truck at the shop. 2 _DAYS_ later I got the call that it was done. "DAMN!!! THAT SUCKED!" "Yeup.. I told ya'!" But, they were good to their word and stuck to the written estimate. The install would have cost me more than double if they had charged me by the hour. (They quoted $300 and they guessed they spent about 10 hours. At the time they were charging $73/hour) So, like I suggested to the guy in the other thread, find a local shop to do it and see if you can get them to give you a written estimate up front. I'd bet that it will save you a LOT of money, unless they happen to know how much this.... sucks. :) Good luck! |
Did we mention the install sucks? :)
I talked to a local general maintenance/exhaust shop, told them the install sucks, they said they would still do it, I said the install REALLY sucks, "we'll still do it", and they quoted me a flat fee. Okay! With a written estimate in hand, I ordered the headers. They came in about 5 weeks later and I dropped off the truck at the shop. 2 _DAYS_ later I got the call that it was done. "DAMN!!! THAT SUCKED!" "Yeup.. I told ya'!" But, they were good to their word and stuck to the written estimate. The install would have cost me more than double if they had charged me by the hour. (They quoted $300 and they guessed they spent about 10 hours. At the time they were charging $73/hour) So, like I suggested to the guy in the other thread, find a local shop to do it and see if you can get them to give you a written estimate up front. I'd bet that it will save you a LOT of money, unless they happen to know how much this.... sucks. :) Good luck! Hey mark honestly for the 600 or so spent including installation you think its worth it as far as performance goes. Did you notice anything in the low end? Did your exhuast tone changed and if so did it sound better or fartier. |
Ok then...maybe this will be the first time I send a vehicle somewhere else :)
So would it be worth the money to send it to a shop? Should I have them JUST do the headers/X-over or should I have them do the exhaust too? I was going to be visiting a shop anyways to get an EGT bung welded on...might as well have them do it... |
Did you notice anything in the low end? Did your exhuast tone changed and if so did it sound better or fartier. Okay... looking back to when I first got 'em, I would have to say that I did enjoy the new torque on the bottom end. Now, there may be some clouding on the timeline here, so I want to be straight about the order that stuff happened in. The exhaust/header thing went like this:
If I were to do it again, I would _NOT_ spend the money on headers unless I had an S/C in a box at home waiting to be put on. The cost/performance ratio is just too lousy. The stock manifold is certainly quite restrictive, but unless you do something to cram more air into the engine, you really don't care. At the time I had the headers on (pre S/C) I had the ISR mod and the deckplate, so I was getting "some" more air in there but I dunno that it was enough to really see the headers do me any good. Hope that helps! |
So would it be worth the money to send it to a shop? Should I have them JUST do the headers/X-over or should I have them do the exhaust too? Oh... sumpin' else! The reason that the install sucks is twofold, 1) those lower bolts, and 2) getting the old crossover out 'cause it runs above the tranny and there's NO clearance to get it out. Now beacause of that crossover routing, most header companies suggest running a crossover _below_ the tranny. The issue here is that if the shop welds on that crossover, then you're not gonna be able to drop your tranny pan. Believe me, I know. This is the 2nd thing that my local shop had to re-do. :) They ended making up a bolt-in piece that works out pretty well. OH! OH! One more more thing... If you're running an auto, then you have a kickdown cable that's currently routed up through the driver's side manifold and heads to the throttle body. MAKE SURE that it's safely routed after the headers go on. "Safely" is defined as not being pulled tight against the headers 'cause the local shop didn't know any better. :( Mine melted stiff within about 20 hours of engine run time before I figured it out (the symptom was the throttle being a BEAR to push on when cold). I re-routed the cable, but it was too late... The cable was beyond hope, and needed to be swapped out. And yes... this is how I figured out that it was a bad thing to have a welded crossover pipe underneath a tranny pan. :) |
Well Mark it looks your torque increase was probally from the pipe diameter reduction. As far what I feel i think its best just to match the diameter of whatever the outlet the exhuast manifold would be. So ill be keeping the stock 2.25 piping. Yeah I always wanted a straight answer from someone who had headers but not a SC cuz Im aiming for a very good non s\c truck. headers are 400 and looks like installation will be another 400 soo its probally around the $800 zone for a lousy +15 hp?
So will see im pretty anxious when it comes to more power to the truck. |
Ive done headers/eshaust installs before. The tacoma is gonna require welding for the exhaust? Where?
I can weld (might not be the prettiest weld, but it works), but no welder...Thats why I needed the bung done. O think Im just gonna have them do the headers and Exhaust... |
I talked to a local general maintenance/exhaust shop, told them the install sucks, they said they would still do it, I said the install REALLY sucks, "we'll still do it", and they quoted me a flat fee. Okay! With a written estimate in hand, I ordered the headers. They came in about 5 weeks later and I dropped off the truck at the shop. 2 _DAYS_ later I got the call that it was done. "DAMN!!! THAT SUCKED!" "Yeup.. I told ya'!" But, they were good to their word and stuck to the written estimate. The install would have cost me more than double if they had charged me by the hour. (They quoted $300 and they guessed they spent about 10 hours. At the time they were charging $73/hour) So, like I suggested to the guy in the other thread, find a local shop to do it and see if you can get them to give you a written estimate up front. I'd bet that it will save you a LOT of money, unless they happen to know how much this.... sucks. :) Good luck! The "hose" on the headers is probably referring to an air injector hose or heat riser hose or something like that. MY guess would be reed valve tubes. You should find out before you buy. |
I can weld (might not be the prettiest weld, but it works), but no welder...Thats why I needed the bung done. O think Im just gonna have them do the headers and Exhaust... The concerns with the Edelbrock install are: The stock cross-over pipe; just sawzall it off, trust me. On the 5 speeds, the clutch slave cyl soft line runs REALLY close to the mating flange for the drivers side bank. I found that out the hard way, as it burned a hole in mine and I lost all hydraulic pressure to my clutch (pulling into my garage no less!). One of the drivers side lower exhaust stud nuts (you'll see) took me 2 hours with a crows foot 14mm wrench, seriously. The cross-under pipe is somewhat exposed if you do any serious wheelin. Not too bad, but enough to want me to have some kind of brace or plating under it. The power gain for me was actually about half throttle around 3K - 4K RPM. It just seems to pull harder there. It also seems to pull harder while cruising in second gear at about 4K RPM and dropping the hammer. I guess I would do it again given the chance. But only because I did the install. An extra $400 to install them would be a red flag for me. |
As far what I feel i think its best just to match the diameter of whatever the outlet the exhuast manifold would be. So ill be keeping the stock 2.25 piping. My decision was based on talking to other folks that have gone through this, and then the info here: http://www.torquetechexh.com/whichsize.htm Yeah I always wanted a straight answer from someone who had headers but not a SC cuz Im aiming for a very good non s\c truck. headers are 400 and looks like installation will be another 400 soo its probally around the $800 zone for a lousy +15 hp?
