Where to get coil spacers?
Where can I buy a pair of rear coil spacers for my 91 Runner? and do they even make front spacers for 2nd gens?
-Chris |
The makers are coil spacers are Downey, Revtek, Daystar, and Cornfed. Here's their sites:
www.downeyoff-road.com www.revtekindustries.com www.daystarweb.com www.cornfedsuspension.com Check 'em out! Chris |
Thanx
Ive got some 2-5/8" Coil Spacers for a 2nd Gen for sale...
They were never installed, I decided to go with longer HD coils instead... These are custom made to fit a 90-95 4runner, excellent shape.. $125 + shipping Thanks, Dan |
Are they only rear spacers? 2-5/8" might be too tall for me. I was aiming for like 1-1/4" to clear 33's with no problems.
I'm not sure about 2nd gen trucks, but for 3rd gen 4runners, you need a minimum of 2" of lift to clear 33's.
Chris |
Youll end up pretty much curing the rear sag, if there is any. If not, all youll need to do to compensate for your rear being higher is crank your t bars a little bit.
Try jacking up the rear of your truck 2-5/8" and look at it. Youll notice that it looks better.... Thanks, Dan |
You cannot get spacers for the front of 2nd Gen runners. They have torsion bars.
You really only need 1" of front lift to fit 33's on a 2nd Gen. This is my truck with a 1" bodlyift and no other front lift. Cranking the torsion bars loses travel and degrades ride unless you have a heavy and I mean capital H heavy front end. Cranking them only gains clearance at ride height. When you compress, it is all gone again. Here is my truck on 33's with a 1" bodylift, some cruiser coils and some long Ranchos. http://www.montypics.com/pic.php?url...8_Dsc00050.jpg It wheels all right. |
Youll end up pretty much curing the rear sag, if there is any. If not, all youll need to do to compensate for your rear being higher is crank your t bars a little bit. I'm not sure about 2nd gen trucks, but for 3rd gen 4runners, you need a minimum of 2" of lift to clear 33's. |
If you were wanting to go with wider tires, just get some cheap ass rims with a 3.75" or 4" offset.. thatll take it out enough so they dont rub..
