Trailer plugin wiring?
:think: I just bought a cheap wiring plugin kit for a trailer. The plug has 4 wires coming off of it Tail, Ground, Left Signal, Right Signal
Where do I plug these in... I have a 1990 4Runner SR5 I have the wires pulled underneath the rear on the left side theres a bunch of wires but I have no clue what to do.. I am pretty positive I know where to plug everything in except the right signal and the tail... any help asap would be great im in the middle of this right now.. |
Assuming your runner has amber turn signals you will need to buy a converter connection (about 10 bucks at auto stores) that will allow a standard dual taillight trailer connection(4 plugs) to function properly with your truck(5 plugs)
You will probably need to do a Y harness on the brake lights from the truck to the connector/converter if I'm correct. I've never done complete trailer wiring before though. The connector you buy will have 5 connections coming in and 4 for a standard trailer. Have fun! Tom |
i did mine a while back, though it did have a horribly done setup on it already that i spent more time cutting out(full of spaghetti wires) than i did installing a new, functional converter. find the wires coming out of your tailights and probe them to find each wire. a good wire tester comes in handy :)
