rear end sag
Hey, I just got a great 91 SR5, I want to customize it, where should I start? I am thinking about shocks to lift the rear end a little. I also need a brush gaurd and winch, what is the best and most affordable? Any info will help, Thanks
Re: rear end sag
Originally posted by Nate Hey, I just got a great 91 SR5, I want to customize it, where should I start? I am thinking about shocks to lift the rear end a little. I also need a brush gaurd and winch, what is the best and most affordable? Any info will help, Thanks oh yes, i almost forgot, welcome to the forum! you will enjoy it:hillbill: |
You could also put in some OME shocks and springs. I put the heavy ones in my '01 4runner.
Yotatech also has a good suspension write-up here. |
Although I have WAAG grille, rear bumper, rear tail light guards - practically everyone on here will tell you to go ARB and WARN for a winch.
I have neither so I can't really help you much on that :D ... and welcome! It's relaxed here and you'll find all the mods you ever wanted to add on to your rig :cool: |
Talk w/ Corey about his set-up. I seem to remember him saying he eventually had to get new TB's. I guess the weight of the winch and ARB were making his rig steer funny and "bob" on the road.
With the additional weight of the bumber and the winch, you'll want to get some aftermarket torsion bars--they're about $50 a piece for Sway-A-Ways. Depending on what kind of rear coils you get, you may find that you'll need new tb's anyway to get the front level with the rear.
Although the install can be a bit tricky, it's not difficult and it's not that expensive considering other mods! SAW tb's will give you a stiffer ride. Matt |
