Multiple questions :)
first my truck came with a hitch and i was just curious how to tell what class it is.....is it was simple as
1 1/4'' - class 1 2'' - class 2 2 1/8'' - class 3 or is it more complicated :redface: second is i got my tranny flushed a bout a week ago and i notcticed on the bill today that they refilled with dexron III, when my manual says D II...is that a prob or is it just that D III wasn't out when my truck was made (92)? and if i ever need to add any i should prob use D III right? thanks in advance |
Gotta use that feature search
:D j/k.. But I just gave a really good reply not long ago to that same question.. Check the "Search" link above for my answer.. :pat: |
where in ATL?
My tranny says Dextron II on the dipstick (insert joke here), but all I could find was Dextron III... I dunno??
I'm pretty sure Dexron II was upgraded to Dexron III, and so it is safe to run DIII in all the older vehicles...it is just a newer ATF fluid.
It's just like DOT3 brake fluid going to DOT4. |
first, my bust on not doing a search, i usually do but i got lazy this time......i figured that the D III just replaced D II....i was kinda hoping that my tranny would explode or something so i could get a new one :bigok: but oh well.....
ryan, i live in dallas, ga which is just west of marietta..... thanks for the info |
Originally posted by CTB I'm pretty sure Dexron II was upgraded to Dexron III, and so it is safe to run DIII in all the older vehicles...it is just a newer ATF fluid. It's just like DOT3 brake fluid going to DOT4. |
When I worked at grease monky they said that Dex III is ok to put into Dex II.
