Mirror/map light additional gauge pod?
Has anyone seen a way to add additional gauges to the pocket area below the map lights?
I'd like to add a couple gauges but I don't want the A pillar pods because I would have to eliminate the grab bar. |
I put mine on top of the dash.
Easy to see not in the way of anything. All my Toyota`s have two gauges up there I did not like the A pillar Pod to distracting to look at for me. |
Originally Posted by wyoming9
(Post 52298075)
I will post one when I get home from work in about 12 hours.
You can put anything anywhere. Offhand, you'll have to lengthen the wires tremendously and route them up there. If you can do fiberglass works, you can make them look good. Do what you want and are capable of. I throw mine on top of the dash in the corner by the windshield personally.
1 Attachment(s)
Here is the ones in my Tacoma
Mechanical oil pressure and Volt Meter One in my 4Runner has oil pressure and Temperature gauge |
