Help! I can't change my #6 spark plug (can't get to it)
I can't get to the #6 plug. The wrench won't fit in between the metal thing not sure what it is(?). How should I proceed? Thanks for your help!
https://cimg2.ibsrv.net/gimg/www.yot...9e896f9178.jpg# 6 Spark Plug, Drivers side, by the firewall.https://cimg5.ibsrv.net/gimg/www.yot...98843250db.jpgView #2, from the top of the engine. |
Can you get a swivel attachment in there with an extension?
I did my plugs, tubes and wires when I replaced my valve cover gaskets (looks like yours could use them too, if you're looking for another project :) ), so I didn't have to deal with this. Everything was out of the way. I'm sure with an extension and swivel you'd be able to get at it, though. Makes it a little easier :) https://cimg5.ibsrv.net/gimg/www.yot...f32f561a6d.jpg |
Can you move metal thing?
May have to remove or loosen a bolt. |
I ended up not needing to move it. A long extension with a 5/8 spark plug socket could sneak to the right of it. Thanks Marc!
When I change my plug I remove the top bolt and loosen the bottom one on the bracket and just move it towards the front. of the engine.
Not like your changing plugs all that often |
Originally Posted by wyoming9
(Post 52343751)
Not like your changing plugs all that often Andreas |
