finding clinometer wire off of dash harness
Hi,
I have a 88 4Runner and just picked up a new dash with clinometer. My question is where is the wiring and plug which plugs into the clinometer. I have the entire dash out and I do not see an extra wire and T-Shaped plug hanging off the harness to plug into the bottom of the clinometer. Did all the 85-89 1st generation 4Runners include the wiring and plug for the clinometer? Any help in locating this wire would be greatly appreciated. Is it hidden behind the air ducts? Regards, David |
Someone just asked this question the other day and here is what seems to be the problem..... Not all Toyotas had the Inclinometers/Altimeter. They "do not need power to work", They are mechanical. The wires are just one hot and one ground for the back lights in the Inclinometer/ Altimeter/ Gauges. I just put one in my 01 Tacoma and I pulled off the front panel around the radio and heater/air buttons. Found a hot wire and and a ground wire on the air bag on/off indicator and hooked it up that way. You can also use the hot wire going to your Cigarette lighter outlet.
Do a search on "Inclinometer" and you will get all kinds of info. Hope this helps, Mike |
i used the wire going to bulb on top of the ashtray as the (+) and just simply grounded the other. thats it.
bob |
