Do it yourself?
Do it yourself job?
http://pics.montypics.com/pinoy/2002.../picture_4.jpg |
Re: Do it yourself?
Originally posted by pinoy Do it yourself job? http://pics.montypics.com/pinoy/2002.../picture_4.jpg How did you do this? Is it the entire thing or just one side? |
What are we supposed to be looking at? The saggy rear end? The little scratch by the taillight?
:dunno: |
If you talking of removing that bumper piece 4 bolts are all that holds it on. I need to do mine on that side because it's rusting where the exhaust exits. See you've got Flares.. Like em?
Love the flares. Is the bumper supposed to sag like that?
That's weird it's sagged in that direction. Most are the opposite from hitting the bumper on the ground when climbing a hill. If your that concerned with it take it off and tweak the mounts a bit. If you look under there there's not much to the mounting system.
I assumed your picture was about the bumber, the gap at the right is greater then the left (either that or it was assembled by GM or Ford)
Joey, do you think it would be just the mounting brackets that need to be reworked a little? |
Chris ya I am sure that's all it is. I doubt the whole bumper would be tweaked but I guess it's a possibility. The factory mounts aren't much...
http://pics.montypics.com/pinoy/2002-12-27/picture.jpg
lowered Rice Rocket... I think it loosened my bumper while rising and falling when i pull forward. |
Ok stop with the nut shots. :laugh:
Jay |
Originally posted by Jay Ok stop with the nut shots. :laugh: Jay |
Just grab ahold of the underside of the bumper and pull it up. That should get rid of the gap. Or drag it on some rocks.
Does your corner jiggle? ugh, well does it appear to be loose?
Chris |
This is totally tight and on there. Not loose at all. Tried to pull it up, but i ended up pulling the whole rear end.
Loosen just the side that is tweaked and see if you can move it then. May require someone to lift while you tighten the bolts.
Jay |
Originally posted by Jay Loosen just the side that is tweaked and see if you can move it then. May require someone to lift while you tighten the bolts. Jay |
Originally posted by Jay Ok stop with the nut shots. :laugh: Jay :laugh: |
:bounce: :bounce:
Originally posted by Jay :bounce: :bounce: :nerd: |
looks like i'm going to have to remove the bushwhacker FF.
| All times are GMT -8. The time now is 01:04 AM. |
