Crickets in my clutch
Guys,
Very odd sound coming from the engine bay somewhere. I was waiting in the drive thru, put the 5-speed in neutral, and let my food completely off the clutch. And then i hear this sound that can be best described as "crickets". I barely put any pressure on the clutch and the cricket sound is gone. Any clue? Bob |
Throw out bearing? anyone else?
Well your first mistake is putting your FOOD on the pedal in the first place!!!:nono:
Fink:devil: |
Re: Crickets in my clutch
Originally posted by Bob_98SR5 Guys, Very odd sound coming from the engine bay somewhere. I was waiting in the drive thru, put the 5-speed in neutral, and let my food completely off the clutch. And then i hear this sound that can be best described as "crickets". I barely put any pressure on the clutch and the cricket sound is gone. Any clue? Bob I think its caused by the throwout bearing. I wouldn't get it done until you need a new clutch. Its an annoying sound, but with your sound insulation project done, just roll up your windows. |
My 96 makes a quiet "turbine" type sound. When the clutch is depressed, it goes away.
Try spraying some Orkin in there and let me know if it goes away. :laugh: |
Originally posted by 4x4Fink Well your first mistake is putting your FOOD on the pedal in the first place!!!:nono: Fink:devil: |
Originally posted by keisur yes, that usually attracts crickets. :hillbill: |
guys,
thanks for the advice re throwout bearing and pesticides. where can i buy some cricket pesticide? will it hurt my MAF in the process if i spray too much? WILL IT INCREASE HORSEPOWER?!!!? j/k Bob |
Originally posted by Bob_98SR5 [B]WILL IT INCREASE HORSEPOWER?!!!? but only if you're asian -_- |
Originally posted by Toyo_Runner96 YES!!!!!!! but only if you're asian -_- |
Me too.
if it's any consulation bobby, my toss off bearing has been cricketing for about a year now and the clutch is still strong. it's the original stock one. I used to squirt white lithium grease in the inspection hole where the fork comes out but I got tired of doing that every couple months so I just live with it. I figure when I replace the clutch that will get fixed but it's not worth tearing it down since the clutch is still real strong. it won't hurt anything.
I used to squirt white lithium grease in the inspection hole where the fork comes out Good to know, thanks. Do you have a pic of the above quote? I may try that. Bob |
Originally posted by Bob_98SR5 Keisur, Good to know, thanks. Do you have a pic of the above quote? I may try that. Bob |
You could have a broken spring in the pressure plate?
Originally posted by <96 Runner> Me too. |
ah so grasshopper...
Asian is not by physical appearance but by state of mind. Or so what my last fortune cookie said ;) I'm going out to buy pesticide for my extra power now :hillbill: |
Originally posted by Bob_98SR5 Keisur, Good to know, thanks. Do you have a pic of the above quote? I may try that. Bob http://www.keisur.com/images/4Runner/bob.jpg |
Originally posted by Toyo_Runner96 You're not asian!! |
I like sushi...does that count?
Gimme some scotch tape(to slant my eyes) and a platter of Kung Pow Chicken and I'll be ready for Horsepower in a bottle...also known as Diazinon(sp?) Fink:devil: |
