Better Cams!?
I bought atermarket cams for my 3.4 Tacoma @ webcamshafts.com. They are great but run way to ROUGH. Does anybody know a differant brand of cams or smoother cams?
Thanks, NX Taco:help: |
These guys mill cams for your engine. Looks like their website is being updated, but they do have contact information. You can also check with these folks.
A question or two about your cams: 1. Did you get new valve springs? 2. How much lift/duration are they? 3. When you say it runs "rough"; Do you mean you have a "Loping" idle or that it runs poorly at any RPM? Just wondering... G |
You are better off staying with the stock cams and using a supercharger and/or doing cylinder head port work. We have experimented with modified cams and found that the stock ones generally work the best overall.
Gadget www.URDUSA.com |
I still have the stock valve springs, the duration is@ .050, and it always runs rough at any RPM.
I would get asupercharger but I already have nitrious(75 shot). |
It sounds like when the cams were reinstalled the gears or the belt was put on one tooth off. Did you get the regrind or hard-weld?
