Best shocks for '99 LTD 4WD?
So now that I have this truck back together and running, it's time to work on some of the suspension that it is lacking
When I come to a stop, the truck rocks back and forth a couple of times--the shocks are THAT worn out, lol. Hitting a bump on the highway and you're bouncing. Also going to replace sway bar bushings while I'm at it, and maybe some other things depending on how bad they look. so, which shocks should I buy? I don't do any offroading and don't have any plans to lift it or anything like that. Local advance auto has some monroe shocks that are pretty cheap. How are bilsteins--harder than stock or better or what? Any suggestions? I drive it 3-4 days a week, mainly on the interstate |
STOCK for a stocker
Seeing that the OEM Tokicos lasted you this long, that would be my suggestion for a replacement. I believe places like ShockWarehouse have them at a decent price.
But if your rear springs have never been replaced that may be contributing to your issue as well. |
I'm looking at the Tokicos at shox.com for $269 shipped. A lot of people like the Bilsteins as well.
I have bilstein shocks on my 98 4runner. I really like them. They are kinda stiff sometimes but not too bad the only time I notice it is when i am not driving. The bilsteins eat bumps up like crazy, you will see a big hole in the road, run over it, and barely even feel it. As Ron Helmuth said, the back springs may be part of your problem too. I know mine has got the saggy ass syndrome really bad which makes it bounce a little at higher speeds.
Originally Posted by Ron Helmuth
(Post 51940288)
Originally Posted by badattitude
(Post 51940293)
Originally Posted by kfarrar
(Post 51940296)
269 for the stocker vs 319 (I believe it was anyways) for bilsteins.
Decisions decisions |
Originally Posted by ncsugrad2006
(Post 51940308)
Decisions decisions Also, if you buy shocks online you should already know how/where they will be installed. Many people install themselves. However, the fronts are just a little too complicated for me to do. I asked around and most shops will not install shocks you carry in. Just be aware of this. |
Heres an idea
check to see if the rear springs in your truck have been replaced by the TSB recall. If not then you could have the shocks installed at the same time as the rear coils are being replaced and end up with an nice set up.
(Post 51940317)
FYI the Tokicos Trekmasters are not exactly the original shocks. They are made by the same manufacture but I don't believe they are the exact same as the awesome OEM 4runner shocks. A set of new OEM from someplace like toyotapartsales.com will cost about $400 IIRC.
Originally Posted by jrm
(Post 51940925)
And if they haven't been changed, will they be changed out for free? |
(Post 51941020)
I pulled the motor when I first got this truck, so hopefully I can manage to change these ;). Just need a spring compressor..pretty sure I can rent one though
I want to learn about this rear spring recall too? I know there was one for 96-98 4runners, but I don't believe it applied to 1999's? did it? How do your rear springs look? Mine appear to have no sag at 140,000. If you have the red/yellowish green coded rears you have the 1999 tall spings, just make sure you get the same color code if they replace them. Fronts should be blue/pink and blue/yellow IIRC |
Addco sway bars front and rear, urethane bushings all around! Made a nice difference for my old 96, even with stock newish struts/shocks.
