Originally Posted by Nervo19
(Post 52116527)
Looks good! You sure got a deal. Did you ever fix the roof? What I was thinking as I was reading is the same as you seem to have decided: grind rust, rust converter paint and Bondo glass. I will add that you could get a piece of fiberglass mat - it comes folded in a bag next to the other Bondo products- and cut small pieces, wet them with the Bondo glass and jam it anywhere you have a hole. If you end up needing paint there's an on line company that will match factory and put it in a spray can:
http://www.paintscratch.com/ |
Originally Posted by chadsy
(Post 52116371)
http://www.ebay.com/itm/Toyota-3-4L-...=Make%3AToyota
I'm a little late to the game with your TB/Water Pump issue, but this kit has OEM parts and a lot of good reviews. http://www.rockauto.com/catalog/more...201&cc=1272596 http://www.rockauto.com/catalog/more...569&cc=1272596 |
