rim size?
1 Attachment(s)
Are these 15x12 or 15x14?
15x2 foot tape would do Waskily, dont rub it in!
Wheels are supposed to be stamped with the size, usually on the inside:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/23.html http://www.4crawler.com/4x4/CheapTri...x/p1030120.jpg |
Sorry found these 4sale on cl and guy don't know the witdh and said no stamp anywhere. i think stamp is in between rim which tires are mounted over.
Well then a tape measure will do the trick, stick the tape through the holes in the wheel and eyeball the width. Just subtract ~1.5" - 2" from the outside to outside measurement in order to get the bead-bead (inside) width. So if your rims measure like 13.5" - 14" on the outside, they are likely 12" wide inside the beads.
Thanks, gonna check it out tomorrow. I thought someone would know by eyeballing it lol, was thinking it's 15x12 but then again looks pretty deep.
How are we supposed to tell just by looking at a tiny picture. The picture isn't even the profile of the rim. We could probably give you some kind of estimate if we saw the profile. I agree with Wabbit.
I would venture to say 15x10 or 15x12 at most. That's a 13.50 tire on it, but it's hard to see sidewall profile.
(I just re-looked and saw that it's a 13.50...) |
I would say they are prob 12's. The tire is a 33x13.50 and judging by past setups I have had I would say the 14" wheel would have the tire stretched out a little more. Hard to tell by the pic though.
