33x12.50 baja claws on 92 4runner?
I have a stock 1992 v6 4runner (automatic so it has 4.88 stock gearing) well it has a airbag lift in the rear but aside from that suspension is stock. My question is will I be able to fit these tires on my stock rims?
Originally Posted by mrbcyota92
(Post 52064216)
you wont fit those tires without a lift. 33x10.50 R15s fit stock with minimal trimming |
Thanks for the reply, I will be doing a 2 inch body lift before attempting to fit them, but does anyone know if the stock rims will fit these tires? As far as checking the VIN is there anything easier then calling Toyota?
(Post 52064244)
stock rims will work. but you can get some 15x8 cragar soft 8s for pretty cheap and make it look a little better |
There is lots of good links in this thread on gearing.
https://www.yotatech.com/forums/f116...osting-204178/ |
My door sticker says "G254" , according to that I have 4.556 gearing I beleive
(Post 52064310)
The 15 inch rims were to small, the tires were R17's (should of realized that before trying to fit them) anyways I managed to pickup a set of 17 inch american racing rims from a 2005 4runner, costed me 400 dollars, sanded them and painted them black. Just got them put on and I didnt even need to install the body lift, so ive decided to go with a 1 inch body lift instead . Right now they rub a little bit when the wheel is fully cranked nothing to worry about though. Im thinking of putting 1 or 2 inch wheel spacers, anyone have any opinions on wheel spacers?
by the way i never did any trimming or torsion bar cranking.
I'm running 33" cooper sst mts under a stock lift on a 98 runner
33 12.50s will fit with a lot of trimming. I gutted about 3" of my front bumper. They now clear... But have not been tested at driving,or off road yet.;
