Kiyo and myself have been thinking about these scoops for a while. Coming accross this thread convinces me to get it. The hole in the hood is getting old.
Originally Posted by vital22re
(Post 51812621)
Install time took 20 minutes. 10 to cut the hood and 10 to wrench the 6 nuts down. I didn't like the hole either... especially since its going to be rain season here real soon! |
just read the whole thread, i'm glad you got it all going! looks great too! i'm really jealous!
Originally Posted by yotasavg
(Post 51813417)
When your 3.0 goes... DO THIS SWAP! No matter how long it takes, you won't regret it! |
Originally Posted by calipatient
(Post 51813419)
I was saying the same thing on other threads last year before I started mine!
1uz would be awesome! Drive that thing until the gasket blows... and it will! ;)
3 scoops ordered. Thanks again. We will have to post up some pics after they are installed.
Originally Posted by kiyobrown
(Post 51813757)
:great:
Had it on the road a little over 800 miles and pulled a check engine light... wierd thing is it goes on for a bit but when the truck has been sitting for a few hours and I take off. half the time it will go off and stay off, until the next couple times I start my truck, then goes back on. I guess I will just have to pull the codes and see whats the deal!
Ever figure out which codes??
The scoops came in yesterday. Can't wait to get it all buttoned up. We will have to post pics when we install them. |
(Post 51818275)
The scoops came in yesterday. Can't wait to get it all buttoned up. We will have to post pics when we install them. Glad to hear they came in I'll start a new thread for scoop ideas/pics in the 3.4 swap section |
just wondering how far the Supercharger sits above where the Hood is, I have a 2" BL that I put on so I could avoid cutting my hood. But that was before I even discovered the 3.4 Supercharged was my option for engine swap.
Originally Posted by X94YODAX
(Post 51829353)
With 2" lift you wont have any problems. I was able to close my hood without even cutting a hole, just the under hood supports... but it did leave a small dent and would rub on the underside of the hood when it rev'd. So as far as how much clearance is need to fit the S/C..? Not much! |
I really didnt want to cut it at first... but didnt want another 2" of lift, its already top heavy as it is... after all was said and done, Im stoked with how it turned out.
Sweet rig!
I'm doing this swap now & was wondering if you have any body lift on this truck and what did you do for the exhaust cross-over? I like the hood scoop idea but I was concerned about exhaust to firewall clearance without doing a body lift. |
Originally Posted by Datsayota
(Post 51834367)
Sweet rig!
I'm doing this swap now & was wondering if you have any body lift on this truck and what did you do for the exhaust cross-over? I like the hood scoop idea but I was concerned about exhaust to firewall clearance without doing a body lift. As far as the crossover I built my own but it took a few trial and errors. Toyonly swaps sells them for like $125, well worth it in my opinion and it looks a lot nicer than mine turned out! |
(Post 51834427)
I noticed in your sig you're supercharged with plans on urd fuel mods. How well has the supercharger without any fuel mods worked? I'm reading anything from it pings quite a bit to people have no issues with running the supercharger without the urd fuel mods? Are you running any type of fuel enrichment other than stock?
Originally Posted by bend
(Post 51835037)
More like 200 for those who are wondering. good job on the build. Hopefully i will get mine started later this week.
Good luck on yours, do the research and everything will fall into place. Any questions feel free to ask. I dont mind answering what I can.
Originally Posted by ultimase
(Post 51835664)
