Done with the front shock hoops!
http://i214.photobucket.com/albums/c...r/IMAG0258.jpg http://i214.photobucket.com/albums/c...r/IMAG0257.jpg |
Rear shock are done! using the factory upper shock locations I build a new crossmember that I could bolt the shocks to. I used 1.5" tubing bent 2 peices at about a 65 degree angle and sleeved the 2 peices together with some 1.75" tubing. After finding where I wanted everything I welded a 3/4 x 10 nut into the ends so I could bolt everything up. worked out pretty slick I must say!
http://i214.photobucket.com/albums/c...r/IMAG0284.jpg Notice the lower Rt of the pick to see where the bolt threads in and where the old upper shock mount is. http://i214.photobucket.com/albums/c...r/IMAG0285.jpg http://i214.photobucket.com/albums/c...r/IMAG0286.jpg http://i214.photobucket.com/albums/c...r/IMAG0288.jpg |
Been a while but here ya go!
Made a rear D-shaft with some left over parts. http://i214.photobucket.com/albums/c...r/IMAG0280.jpg Got the brakes done. http://i214.photobucket.com/albums/c...IMAG0285-1.jpg http://i214.photobucket.com/albums/c...IMAG0278-1.jpg Detroit is in the front, along with a Tom Wood shaft. http://i214.photobucket.com/albums/c...IMAG0272-3.jpg http://i214.photobucket.com/albums/c...IMAG0286-2.jpg |
Then did a little wheelen.
http://i214.photobucket.com/albums/c...7/IMG_1312.jpg http://i214.photobucket.com/albums/c...7/IMG_1330.jpg http://i214.photobucket.com/albums/c...7/IMG_1297.jpg and ruined a power steering pump, Toyota steering dosent agree with a locked dana 60 on 39.5's. :hillbill: http://i214.photobucket.com/albums/c...7/IMG_1333.jpg |
Woah, jesus... Are you not afraid to roll this rig over? O.o
So much lift for 39,5" tires! :D |
Originally Posted by ulfr
(Post 50714094)
wow thats nice, Im drooling...
Nice rig man :guitar: the tank kinda reminds me of how I did mine. Keep it up its a sick 4runner :hillbill:
Do you still live in oregon? Only asking since i see you have OR plates, but says youre in Utah now.
Nice freakin build btw! |
Born and raised in Oregon, Im military and just can't give up my residency to my home state. Needless to say I get great opertunitys to go wheelen in other states!
Originally Posted by fillsrunner4
(Post 50727583)
Originally Posted by smashmetal
(Post 50732736)
I have to say, I hate the gas tank location/size. Only thing I did to is was cut an access hole under the back/pass seat so I can reach my fuel pump.. I do NOT want to to have to drop that stupid thing again.. http://i19.photobucket.com/albums/b1...8/IMG_1925.jpg:hillbill: http://i19.photobucket.com/albums/b1...8/IMG_1927.jpg |
awesome truck!!
Lots of updates!!!!!
4Xinovations T-case mount.
http://i214.photobucket.com/albums/c...r/IMAG0532.jpg http://i214.photobucket.com/albums/c...r/IMAG0541.jpg http://i214.photobucket.com/albums/c...r/IMAG0542.jpg Rear Detroit and some diff protection http://i214.photobucket.com/albums/c...r/IMAG0534.jpg http://i214.photobucket.com/albums/c...r/IMAG0539.jpg http://i214.photobucket.com/albums/c...r/IMAG0572.jpg installed http://i214.photobucket.com/albums/c...IMAG0577-1.jpg |
Sreering
All the parts for moving the steering box foward, saginaw style pump, hydro assist and high steer.
http://i214.photobucket.com/albums/c...IMAG0574-1.jpg http://i214.photobucket.com/albums/c...IMAG0576-1.jpg http://i214.photobucket.com/albums/c...IMAG0575-1.jpg I already had the Rt side arm. http://i214.photobucket.com/albums/c...r/IMAG0549.jpg http://i214.photobucket.com/albums/c...r/IMAG0550.jpg |
Removed the ABS crap.
http://i214.photobucket.com/albums/c...r/IMAG0545.jpg http://i214.photobucket.com/albums/c...r/IMAG0546.jpg removed the stock steering pump. http://i214.photobucket.com/albums/c...r/IMAG0547.jpg |
Removed the ABS bracket from the bottom of the ABS pump to reuse, the stock steering pump hoses clap to this bracket. So to make it easy I just put it back.
http://i214.photobucket.com/albums/c...r/IMAG0604.jpg http://i214.photobucket.com/albums/c...r/IMAG0605.jpg Made some brackets for the Saginaw steering pump from 3/16 plate. http://i214.photobucket.com/albums/c...r/IMAG0620.jpg http://i214.photobucket.com/albums/c...r/IMAG0618.jpg http://i214.photobucket.com/albums/c...r/IMAG0617.jpg http://i214.photobucket.com/albums/c...r/IMAG0616.jpg Moded the original ajustment bracket a bit. http://i214.photobucket.com/albums/c...r/IMAG0615.jpg http://i214.photobucket.com/albums/c...r/IMAG0583.jpg http://i214.photobucket.com/albums/c...r/IMAG0582.jpg http://i214.photobucket.com/albums/c...r/IMAG0581.jpg |
Mounted pump, still uses stock size belt and had the stock hydro lines for pump moded to fit.
http://i214.photobucket.com/albums/c...r/IMAG0606.jpg http://i214.photobucket.com/albums/c...r/IMAG0610.jpg http://i214.photobucket.com/albums/c...r/IMAG0584.jpg http://i214.photobucket.com/albums/c...r/IMAG0585.jpg The stock steering pump has 2 vacum lines running into it, simply remove one and loop the other on into the empty port. http://i214.photobucket.com/albums/c...r/IMAG0642.jpg http://i214.photobucket.com/albums/c...r/IMAG0643.jpg |
Moved the steering box foward.
http://i214.photobucket.com/albums/c...r/IMAG0612.jpg Had to clearance the frame on the bottom side so the tie rod nut on the pitman arm would clear. http://i214.photobucket.com/albums/c...r/IMAG0613.jpg Added a plat across the top with some flared holes. http://i214.photobucket.com/albums/c...r/IMAG0614.jpg Poerted the steering box for hydro assist and clearanced the core support and fender-well a bit. http://i214.photobucket.com/albums/c...IMAG0621-1.jpg http://i214.photobucket.com/albums/c...IMAG0619-1.jpg http://i214.photobucket.com/albums/c...IMAG0620-1.jpg |
Using a stock toyota V6 power steering resivor I moded it for the cost of a $5 heater hose fitting to fit my application.
http://i214.photobucket.com/albums/c...IMAG0616-1.jpg http://i214.photobucket.com/albums/c...IMAG0615-1.jpg Drill out to 9/16, makes a nice fit later. http://i214.photobucket.com/albums/c...IMAG0617-1.jpg http://i214.photobucket.com/albums/c...IMAG0618-1.jpg Made a quick mounting bracket and booger welded the fitting on the bottom, looks like crap but it dosent leak. http://i214.photobucket.com/albums/c...IMAG0621-2.jpg http://i214.photobucket.com/albums/c...IMAG0620-2.jpg http://i214.photobucket.com/albums/c...IMAG0619-2.jpg |
