| lucasjl |
Nov 8, 2017 12:50 PM |
2008 4 runner 4.7L V8 Starter Bolt Access
I'm trying to help my friend replace his starter. I have the intake manifold off. There is a black harness cover against the firewall and two air valves under that blocking access to the starter bolts. I have found procedures for some earlier models and for a Tundra which doesn't have as much "stuff" packed in there and with the manifold off you can get the bolts. I can't move the black harness cover out of the way either. It appears that part of the harness goes down into the firewall. Does anyone have a procedure to get at the starter bolts. Thank you very much for your help. JLL
