YotaTech Forums
-   General Vehicle Related Topics (Non Year Related) (https://www.yotatech.com/forums/f123/)
-   -   water[ coolant] coming from timing chain cover (https://www.yotatech.com/forums/f123/water-coolant-coming-timing-chain-cover-302045/)
glassbysam Oct 5, 2017 08:39 AM
1994 toyota pickup. 22RE emgine jut installed remanned engine 2500 miles ago
How can coolant [water] be leaking from timing chain cover? could it be leaking from head gasket and going into the timing chain cover?
thanks in advance
irab88 Oct 5, 2017 08:42 AM
VW Bugs are air-cooled, there shouldn't be any coolant anywhere.
gsp4life Oct 5, 2017 10:17 AM
The water pump is on the timing cover. Can you tell where it's leaking from? Run the engine with the hood open and pull the throttle cable to rev the engine. Should spray or drip out faster and you'll know right where it's coming from.
irab88 Oct 5, 2017 11:03 AM
Ah! It's a 22R-E... :chairfall
Also check the water pump. Sometimes those can have a bad seal/gasket.
gsp4life Oct 5, 2017 11:09 AM
I figured you'd just smoked something or other. I was kinda jealous!
irab88 Oct 5, 2017 11:21 AM
Nah, OP just said his engine was leaking coolant without stating what engine he had. I just assumed it was a VW Bug!
Anyway, to help out with the leak:
https://www.yotatech.com/forums/f116...l#post51705070
This is from when I did my front-end rebuild. There is a coolant pipe that goes under the exhaust; check around there. It tends to not seal if not torqued properly.
