YotaTech Forums
-   General Vehicle Related Topics (Non Year Related) (https://www.yotatech.com/forums/f123/)
-   -   Links to Factory Service Manuals part numbers (https://www.yotatech.com/forums/f123/links-factory-service-manuals-part-numbers-102344/)
CyMoN Dec 22, 2006 12:47 PM
*Mod Edit* Hey all, I cleaned this thread up a little since it expanded from FSM (Factory Service Manuals) to links for anything Toyota! A huge thank you to CyMon for starting this thread. Also I deleted some of the posts that were just chit chat so it is easier to find the links you need. Lastly I moved this to general tech since these links cover all Toyota's and not just the 85-90 specific ones. Thanks! -Molly
this is a link for Field shop manual,FSM ,factory service manual what ever you want to call it this is not a haynes or chiltons this is the real deal. it is in PDF file.
for 4runners and trucks of many years I think there are more links on some of the other pages on that first thread.
http://www.4x4wire.com/forums/showfl...5&o=14&fpart=1
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
member Toyotero posted up this but it looks like it got passed up so I am linking it here
https://www.yotatech.com/forums/f115.../#post50938942
this link is for 85 through 2005 trucks and 4runners there are 5 or 6 manuals to choose from
http://www.ncttora.com/fsm/index.html
and heres a list of part numbers for 80's trucks and 4runners.
Lysmachia Jun 27, 2007 06:20 PM
Stickied!!!!
And here are more realevant links:
As well as this one from Mike Ross
http://sn4wd.com/~mike/357/
More good FREE links! (A lot of this I took from my CoTTORA thread - "Reasearch Links For Toyota Gear Heads"
http://www.ttora.com/forum/showthread.php?t=82481
http://www.4x4wire.com/toyota/mainte...nd/solid_axle/
http://www.4x4wire.com/toyota/mainte...d/hub_rebuild/
http://forum.ih8mud.com/79-95-toyota...b-rebuild.html
http://www.off-road.com/offroad/arti....jsp?id=399668
http://www.gsp9700.com/pub/search/findgsp9700.cfm
Here are the few I have gleaned from Troy... (Troy feel free to edit this post with better descriptions that I have given!)
* http://www.bobistheoilguy.com/ - Everything you wanted to know about Motor Oils and lubricants.
* http://www.4crawler.com/4x4/index.shtml#top - 4Crawler's 4x4 Information - This site is a wealth of Toyota Info!!! (He also sells parts new and used)
* http://www.4x4wire.com/toyota/? If you can't find it... look here... an extensive list of how to for toyota. You name it - they cover it.
* http://www.ttora.com/wiki/index.php/Main_Page The OFFICIAL TTORA FAQ and Knowledge base....
* https://www.yotatech.com/wiki/index.php/Main_Page The Yotatech Wiki. Well established and a lot of info there.
* http://www.ultimateyota.com/index.ph...=40&Itemid=137 This is the UltimateYota Wiki. The site is young so not too much there, but there are some knowledgable peeps there, so check it out. You do need to register in order to view the forum.
* Not a URL but a worthy thread about onboard air: http://www.ttora.com/forum/showthread.php?t=82448
Originally Posted by RedRunnertc (Post 1018588)
FSM for '93 Pickup
Differential Info thread (includes link to how to mod preTaco housing for elocker)
http://home.4x4wire.com/erik/diffs/
Link suspension design
http://www.avalancheengineering.com/july2003.htm
Originally Posted by Volcom (Post 1018557)
Best link in the world when it comes to Toyota trucks
Pirate 4x4 FAQ
Originally Posted by Ric (Post 1018149)
If I can post here, heres a link to lots of links http://mywebpages.comcast.net/jonmar....htm#bodyparts
Originally Posted by spindleshanks (Post 1018166)
www.gadgetonline.com
Great articles, experiments on K&N, deckplate mods, FIPKs, etc, and actual dyno tests to prove the data.
More from Troy:
FSM for '93 Pickup
And from a buddy on TTORA
Originally Posted by TEJASYOTA (Post 1070773)
Suspension mods for the IFS - Only Coil overs, bump stops and leafs.
Hidey-ho, neighbor and anyone looking to do a lift is to ask these simple questions.
1) How much are you willing to spend
2) What type of off roading are you going to do
3) What type of driver are you
4) Is your truck a DD or trailer rig
5) Do you plan to haul stuff and how much
6) Did your wife/gf approve the purchase
Use these links below to read and understand....
CustomTaco's only piece of good info for off roaders.
Parks Offroad.com-installation and opinions
Body Lifts - answers by 4crawler.com
Lift - - the question - click here.
LEaf spring opinion poll.
Cams vs Hoes - mandatory reading
Toyota.off-road.com CO-Shock comparision
Downey-Off Road, CLick on to Suspension then the model year of your truck
UCA information
Shackle's anyone? - click here.
Shackle's anyone part II? - click here.
Timbren Bump Stops - click here.
That should be it...but to read, learn, listen and if possible, ride with some guys that have different systems to see how they like it and how it handles.
Good Luck!
Originally Posted by DelveDS (Post 1070540)
www.gearinstalls.com - This guy walks you through toyota gear installs with pics and everything
www.sonoransteel.com - Info on a bunch of mods, e-locker retrofit, arb install, marlin dual case install etc on a 3rd gen 4runner.
www.larsdennert.com - home made rock sliders with air tank capability and other mods.
http://www.precisiongear.com/pgtechpatterns.htm - gear contact patterns
http://www.traildamage.com/ - Trail descriptions, I don't think you were asking for this Molly, but here ya go!
http://bushducks.com/tripreps/passopen.htm - Trail opening dates for Colorado, see the previous year descriptions from other offroad enthusiasts. Again, I don't think you were asking for this...
CyMoN Aug 21, 2007 10:47 PM
added a new link http://www.ncttora.com/fsm/index.html
TNRabbit Aug 22, 2007 10:17 AM
93 trucks: http://personal.utulsa.edu/~nathan-b...fsm/index.html
89 trucks: http://www.brian894x4.com/Scannedmanual.html
More:
http://www.4x4wire.com/toyota/maintenance/
http://www.off-road.com/toyota/tech/
scrid Oct 14, 2007 08:30 AM
93 FSM manual iso
Hey everyone, I hope I'm not stepping on anyones toes here, but if so please let me know.
I liked the idea of the online 93 fsm, but fear that the site may go down eventually prompted me to find a way to save it.
I copied the site to my hard drive and made an ".iso" file that you can download and burn to cd.
You should be able to right click the file after downloading it,...and burn the iso image with whatever cd / dvd burning software you have installed.
It has an "autorun" feature that should automatcally bring up the index page when the cd is inserted after burning.
Unless your pc has 'autorun' disabled, if so heres a link to explain how to re-enable it.
http://www.moonvalley.com/products/rwavdc/enable.htm
I have included a folder on the cd iso which contains Adobe Reader 8, in case it is needed on your pc to view the pdf's.
The .iso is roughly 59MB and I didn't have any space that large to host the file so I registered with a new free site that offers 2GB.
I had to use winzip to package the .iso since the file hosting space wouldn't allow hosting of .iso's. Hopefully this will work.
Heres the link to the zipped .iso:
http://www.snapdrive.net/files/502119/93%20SERVICE%20MANUAL.zip
Heres a cheesy cd jewel file made with Roxio.
http://www.snapdrive.net/files/502119/1993%20Toyota%20Truck%20%26%204Runner%20Manual.zip
raygun Jan 6, 2008 06:12 AM
This first link doesn't work.
I'm trying to find a manual for my 79'
CyMoN Jan 6, 2008 10:43 AM
fixed it looks like they don't have a 79 FSM
4runnerchevy Jan 6, 2008 11:03 AM
Not FSM but related
2 Attachment(s)
22RE CPU CHart
Attachment 193145
22RE pinouts
Attachment 193146
1990Runner Jan 26, 2008 04:03 PM
why do they have an fsm for 4runners and trucks 86-95 with the 22-re but not the 3vze? i know about the 93 truck and all but whats up with that???
thook Feb 24, 2008 11:36 AM
ATTN: Mistake in '93 FSM....A BIG ONE!
http://personal.utulsa.edu/~nathan-b...34electron.pdf
I think for everyone that would be concerned, it should be known that on pg. AT-131 the procedure for the testing of, description of, and location of the #2 speed sensor on (atleast) the A340H transmission is incorrect.
See post #45:
https://www.yotatech.com/forums/f116...l#post50760850
thook Apr 12, 2008 04:21 AM
I've found this site to be helpful; http://www.autoshop101.com/
Currently, I've been reading about this.....a prime example:
http://www.autoshop101.com/forms/h21.pdf
clamd1p Aug 8, 2008 12:18 PM
file not found.... sadness...
Lysmachia Aug 9, 2008 10:06 PM
I have a pretty phenominal TOY FAQ (10 MG) that I got by donating 25 bones to Pirate through The Friends Of The Rubicon. It's incredibly thourough, thoug I can't easily post it or send it (10 MB remember) And I wouldn't want to bypass the reason I got it which was by donating to FOTR on Pirate, but if ya really need it PM me and I'll see how I can get it to you...
a4runnerfreak Aug 9, 2008 10:54 PM
yahoo.com can send up to .....10MB
cableguy103 Aug 26, 2008 07:29 PM
Any FSM for a 82, even a wiring diagram would be helpful.
Lysmachia Aug 27, 2008 12:51 AM
Didja try searching? A lot of folks once they buy the online FSM will host it. :dunno:
I am sure you already looked otherwise you wouldn't be asking I guess? :D
MattGGT Sep 1, 2008 09:17 AM
Just to jump in and deviate from that slightly, (and going into complete cadging mode), :D if anyone does ever happen to have a digital copy of a manual which I haven't already got up on the site that they wouldn't mind sharing, I'm always looking for new additions. :)
Lysmachia Sep 4, 2008 02:32 PM
Matt I have a wonderful Toyota FAQ I got from Pirate but they ask that those who need it send $5 to a charity I think Friends of The Rubicon in CA. At any rate I would be willing to give you some teaser stuff from it and then if anyone wants the whole thing they can buy it. Would that be ok?
cbrsport17 Sep 13, 2008 03:12 AM
This will prove worthy when i am in Turkey!!! Thanks guys...
MattGGT Sep 20, 2008 03:37 PM
Apologies for the belated reply. I have a bad habit of becoming horrendously sidetracked. :D That would be lovely if you could. :) Hopefully, it may help to generate more donations for their cause. :)
