AIR FILTER (What are symptons of bad Air Filter?)
OK all, I have a 95 3.0 runner. I would like to here what you all think the symptons of a dirty air filter would be.
Decrease milage and performance.
Are you kidding? Look at it and see if it's dirty!
Lamm |
:good: hold it up tot he sun. if you cant see light its bad.
You guys use air filters? I run mine open. So much better throttle response!
Originally Posted by 4x4Lamm
(Post 50393288)
Lamm |
x2 on just look at it... when in doubt just buy a new one.
As I understand it, a normal air filter will become more and more obstructed causing lower MPG, higher smog ratings and overall crappy performance untill the day it is so cloged the motor won't even run.
Lamm |
problem is, a completely clogged filter might also let particles past, hurting the engine...
