22re distributor install
So I'm in the proses of putting the engine back together after doing a head gasket and new head.
My shop manual says to get the bottom end at #1 TDC the crank marker should be at the 0 mark. But I just watched a video on you tube by a reputable company that said for fuel injectors 22re engines the crank mark should be at the 5 mark. What's correct? |
I like the first video link below. For a 22re, setting it at the 5 mark, I have been right on when everything goes right.
A Timing Video I like Better. Set Crankshaft pulley to 5 degrees. Timing Video http://www.youtube.com/watch?v=9qEQM...ature=youtu.be Easy way to install distributor on Youtube. |
Thanks!
Got it all worked out, and running like a champ :) |
| All times are GMT -8. The time now is 02:34 AM. |
