power problems think its my distributor any help thanks
think my dis is messed up starts ok but stutters when i go to give it power truck is a 93 4runner limited 3.0 sr5 with 200000 thanks a lot :king:
Check it for codes first before you throw money at it. Try this link
https://www.yotatech.com/forums/f116...runner-214946/ Why do you think you distributor is at fault? Have you checked your plugs to see what they look like? Have you checked for a loose plug wire?(more common than a bad distributor). Have you checked you oil for water and radiator for oil. 3.0's are notorious for head gasket issues? Tell us what you have checked and we can help you more. |
had it running and went to tuck the dis and got a bad shock plugs seem all right lol did a pressure test on rad its not the head gasket iv had that checked out but i also think my exost is pluged from carbon and all so truck seems to not like 4th or 3rd just don't want to stay in the gear and just switches to the next its a auto don't matter if od is on or off have looked for vac leaks and trans fluid not sure wa to check next i have a good bit of mechanic skills but this has me iv cleaned the tb out new used tps and mas thanks
Have you checked what happens when you pull a plug wire off one spark plug at a time when she's running. That will help eliminate a lack of fire from one or more cylinders. If you pull a wire off and it doesn't make any difference in how it runs. Then you can at least look in a direction. Is the cap arcing on the inside? Did you check it for codes?
gona try running the codes after work my cel olny comes on after i hit about2000 rpm and ill give the plug thing a try and i don't here it arking in the dis but any time its wet thats the olny time it will stutter thanks for the link on how to get the codes fish guy carry helpful ill put up my codes wen i get home
Yea if the light is coming on intermittently then that might be your problem. Let's hope at least. Good luck with the codes. Hope it's a cheap fix
thanks and i hope its a ez fix!
got a code 52 knock sen is lose or something
I have never seen the Knock Sensor fail, it has always been the wire to it. Suppose it could fail but not in my past experience. On your plug wires, I get Denso off of ebay for the same price as top shelf brands at the part store and the Denso wires are so much better. A good way to check for arching is in a dark shop or dark road with the engine running. You might find all kinds of blue sparks under the hood.
Distributor cap and plugs are competitvely priced at the dealer. Much better quality. (Dealer is good source for your oil filter as well) When I see intermittent Check Engine Lights and no codes usually is a vacuum leak. I would suggest checking or replacing your vacuum lines. Go to the parts store and get several feet of vacuum line and replace on section at a time. |
right on thanks not to sure were all the lines are at but iv been held up cuz we have had a bunch of snow in canada and i don't have a shop. I'm getting a dis plugs and wires wen i get the $ just blew a back brake line so iv done all new brake lines do u have a link for the vac lines
