o2 Sensor
Hello,
I am connecting a new "generic" O2 Sensor to my 4runner. I am at the stage of connecting the existing plug end to the recently purchased generic sensor and ran into a small issue: The generic sensor has 2 White + 1 Gray + 1 Black wire The existing plug end has 1 Blue + 1 White + 2 Black wire. What wires connect to what, especially if Black is ground ? FYI - I am getting 250Km per 50L tank of Fuel. OUCH!!!!!!!!!!!!!!!!!!!!!! Sure hope this helps!!!! Cheers to all! |
What truck and engine do you have ?. sometimes the generic 02 sensors don`t work very well on our engines, i hope its not a Bosch 02 sensor, because there junk.
www.densoproducts.com has the best prices on 02 sensors that ive found. |
Ouch, ummmm it is a Bosch.
i am on the 22 re - 1988 4runner |
Bosch does make a bad ass alternator, life time warranty and if the alternator ever leaves you stranded they will cover the cost of the tow truck........
Originally Posted by Gnarly4X
(Post 51305717)
Why are Bosch sensors junk?
Good tip on the Denso site. Thanks, gNARLS. |
(Post 51305717)
3 of the 6 Bosch plugs actually fouled in my engine (I don't have any problems with the NGKs and it's been 2 years) and my new front Bosch O2 sensor started throwing codes within a year. |
Originally Posted by landin
(Post 51305699)
Hello,
I am connecting a new "generic" O2 Sensor to my 4runner. I am at the stage of connecting the existing plug end to the recently purchased generic sensor and ran into a small issue: The generic sensor has 2 White + 1 Gray + 1 Black wire The existing plug end has 1 Blue + 1 White + 2 Black wire. What wires connect to what, especially if Black is ground ? FYI - I am getting 250Km per 50L tank of Fuel. OUCH!!!!!!!!!!!!!!!!!!!!!! Sure hope this helps!!!! Cheers to all! sig+/sig-/heater/heater more info here: http://boschoxygensensor.com/411.asp...20Instructions the bosch colors are same as vw/audi. p.s. if you can return that sensor, get a toyota or denso instead. auto electrical secret tip: denso for toyota. bosch for vw/audi. i don't know what it is but it's proved to be the case for too many people, too often, to be overlooked. good luck |
