how high can i go?
im considering lifting my truck this is my first truck and i went toyota so already im off to a good start. my question is how high can i lift my 91 pickup extended cab v6 without having to do anything else like lengthining steering column or driveshaft, etc....? how high can i go and how high is too much? thanks.
dude seriously, do some research. there are loads of threads about lifts.
:facepalm:
Read all of these. https://www.yotatech.com/forums/f116...tickys-242840/ :wave: Welcome to the forum! What are your plans for the truck? My advise is lift only as much as needed. |
342,246,958,123.223 micro meters....
Originally Posted by yotaman85
(Post 51861901)
Originally Posted by Team420
(Post 51861905)
lol... what exactly is a micro meter? :lof:
(Post 51861905)
http://www.bgsu.edu/departments/chem...9/Prefixes.jpg :wabbit2: |
so wouldn't 342,246,958,123.223 micrometers be pretty tall lol
Originally Posted by Leviticus6432
(Post 51861930)
Haha. I dont really know what its equal to. |
(Post 51861900)
:facepalm:
A Micron is a 1000x's bigger than what I build at work:P
Edit: this is a great link too: https://www.yotatech.com/forums/f120...mation-121264/ |
its about 28,580 feet.
Originally Posted by alpha1eleven
(Post 51861940)
thank you very much, that was very helpful. sorry i didnt find it before but im new to this site so please forgive me. as far as my plans go, im not sure what all my options are yet but i just like having a truck that i can use as a survival tool if necessary. i just got the truck a week ago and so far all ive done is primer it and today i put a 12,000 lb. winch on it. i am up for any other suggestions. thanks again.
Get a good set of tires, and some armor and have fun! These trucks are pretty capable stock. Got any pics of your truck? |
(Post 51861956)
A winch is a good start!
Survival tool you say uh. You should only lift the back. About 6 inches. That way when you put 6,000 pounds of survival gear in the back it sits level.
:helo: 50 battery's, 200galons of water, 400 gallons of whisky, a dvd player, 42'' LCD, spare liver,............................................ ..... . . . .. it keeps going........:shocked: |
lets try this again... welcome to the site, it will, no doubt, be an amazing resorce for learning.
if i was you, i would get some body armor and lockers. then hook your self up with some good tires that are as big as possible WITHOUT lifting the truck. you will be able to keep your steering alive alot longer that way.. how about some pics of your rig.. by the way, the flaming is part of the noob questions. although you got it alot less then others. just be glad this isnt pirate4x4.. |
X2. Welcome... I was abvoisly kidding. Hope you saw it that way.
I often find my truck with at least 1000 pounds of camping gear. Especially when prepping for long trips. Its like playing tetris in the back of your truck. Im rambling but theres a point, consider the gear and the weight you'll be hauling around when choosing your lift. It seems to get overlooked a lot. But at the same time don't stick 1ton spring under there if your hauling a tent and a lawn chair most the time. Best of luck with the new project :) |
Originally Posted by ThatGuy1295
(Post 51862063)
Yeeees sir :bowdown:
1 Attachment(s)
(Post 51862056)
