Daily driving with dual transfer cases?
Looking at buying a toyota with dual cases. Just wondering how it would be daily driving it.
I lost about 2mpg, but other than that have had zero problems with mine.
It shouldn`t be a problem at all as a daily driver.
I'd imagine slow, if you used low range...
Originally Posted by tried4x2signN
(Post 51544547)
:dj: |
if they are set up properly it should not be an issue...you will notice some more gear noise and the duals seem to generate more heat...
Originally Posted by tried4x2signn
(Post 51544547)
i'd imagine slow, if you used low range...
Lots of things you can do you should not do.
Mine were hot and noisy and at high speeds blow oil out the breather and make a mess. I would not have duals in a daily driver personally. :guitar: |
Drive mine everyday. I'd test drive the rig really well if its not set up right it'll let you know.
My '85 dual case 4Runner gets DD much of the time and no issues with noise or oil fumes for the most part. I do get a little more heat from them on high speed runs and in just the right conditions of cross wind and speed, I will occasionally get a whiff of gear oil in the cab, but once I finish venting the cases up into the engine compartment, that should be a non-issue.
I use the 2L gear range all the time, though. Handy for parking or getting in and out of tight spots or in stop-n-go traffic. |
id hate to invade the op's thread, but this could help me and the op.
but how about daily driving witha marlin crawler twin stick? |
I have no issues with dual cases other than a bit more noise. I don't blow any oil out. I never had issues with heat. Things are warmer after the drive train lift, but that's not surprising due to the fact the cases sit right next to me in the cab now.
I'd say its fine. Its not going to be a Cadillac on the road, but I assume you know that. |
Originally Posted by 85gijunk4x4
(Post 51545352)
