tahoewes |
10-27-2008 12:12 AM |
92 4runner 3.0 roll over won't run
I rolled my 92 4runner 3.0. The only damage was to the air box. There was no oil inside the VAFM. I have cleaned out all of the oil and such. Plugs were covered in oil and have been replaced. It turns over just fine and the bottom end is turning freely. If i unplug the VAFM it will run for 3-10 seconds(any throttle play and it shuts off) then shut off. With the VAFM plugged in it won't start at all. I realize that the fuel pump initially runs off the ignition and then the VAFM. Does this sound like a bad VAFM or is there something else I should look at?
